Dead sourdough?
  • DrakeRemoray
    • Mar 2006
    • 1215
    Dead sourdough?
    I have not fed my sourdough culture for several weeks, and this morning I went to feed it and it was NASTY! I actually almost puked when I stuck my nose in there.
    So I threw out the top and scraped a little of the white solid part from the bottom and fed that. Do you think that will work or do I need to start a new culture?
    Yech, I can still smell it now!
    Drake
    My Oven Thread:
  • rlf5
    • Jul 2007
    • 322
    Re: Dead sourdough?
    Not quite sure, but its worth a try to see if you can revive it. I took my starter out and fed it before going on a week long vacation...only thing is I forgot to put it back in the fridge. Needless to say when I returned home it looked dead as a doorknob. Took a couple days of feeding it every 12 hrs at room temp to bring it back. Good luck!
    Oven Progress
    Bread Photos
    Oven Stand Thread
    • PizzaPolice
      • Sep 2006
      • 338
      Re: Dead sourdough?
      Yep! Keep feeding it. Dump half of it out. Use equal measures of flour and non-chlorinated water. Stir. You should have it back in a few days.
      If you are not going to use it for an extended time, Feed the healthy mix and stick it (covered) in the fridge.
      • Ed_
        • Apr 2008
        • 139
        Re: Dead sourdough?
        I think puke-inducing smells are a little worrisome, but that being said... I have left my starter for over a year and successfully revived it. When left for a long time, it does get that sort of black layer on top. I just stirred it back in and started the routine PizzaPolice mentioned--toss half of it, and expand with equal weights flour and water. I left it at room temperature and fed it once a day; it was fine after a few days.
        Let your nose be your guide--if it still smells nasty after a few feedings, something bad probably started growing in it. From what I've managed to learn, a more acidic starter will survive periods of dormancy more successfully.
        • Dutchoven
          • Apr 2007
          • 931
          Re: Dead sourdough?
          Hi all!
          Describe a little bit more what "nasty" meant. The smell could have been due to an abundance of alcohol and stuff. If the "hooch"(liquid layer on top) did not have a pink or green color it was probably OK. It would have been better in that case to stir in the "hooch", discard half the starter, and gently feed the remainder much like you would when starting it. Let me know because you may be able to revive it without much trouble!
          Dutch
          • DrakeRemoray
            • Mar 2006
            • 1215
            Re: Dead sourdough?
            No, I know the hooch smell. I mean I literally almost threw up...twice! I fed it, but there is still that "off" smell, not as strong but still there. I am afraid I have introduced some mold or other off flavor and may have to just start over.
            My Oven Thread:
            • BrianShaw
              • Jul 2007
              • 308
              Re: Dead sourdough?
              I'd get rid of it and start over again... but that's just what I've done when the smell was strong enough to make me vomit. Fortunately it was just a one-time occurance.
              • DrakeRemoray
                • Mar 2006
                • 1215
                Re: Dead sourdough?
                I think I will...from now on, I will keep it in the fridge when I am not actively using it...
                My Oven Thread:
                • BrianShaw
                  • Jul 2007
                  • 308
                  Re: Dead sourdough?
                  Mine stays in the refrigerator now. The only frustration is fif I forget to take it out several days before a baking session to revive it. I've let mine sit for a couple of months in the refrigerator and with 4 days of feeding had a very nice starter.
                  • DrakeRemoray
                    • Mar 2006
                    • 1215
                    Re: Dead sourdough?
                    I had it on the counter, unfed, for a month before, but that was in winter when the house is 68 degrees. I think it spoiled in the warmer weather...
                    My Oven Thread:
                    • PizzaPolice
                      • Sep 2006
                      • 338
                      Re: Dead sourdough?
                      Whoa! In that case, you'll need to call Dr. Frankenstein. Hope you saved some flakes from a previous mix.
                      • Dutchoven
                        • Apr 2007
                        • 931
                        Re: Dead sourdough?
                        If the smell was that "off" it is best and safest to just throw it out. The hooch would have smelled kind of like beer or wine. Store it in the fridge though...from now on...the cooler drier environment tends not to let the unwanteds in
                        Dutch
                        • SpringJim
                          • Apr 2008
                          • 562
                          Re: Dead sourdough?
                          Makes you appreciate the old "sourdough" cooks that kept that stuff going in the old days!
                          • Dutchoven
                            • Apr 2007
                            • 931
                            Re: Dead sourdough?
                            Rumor has it they sometimes kept the starter in a pouch hung around their neck...betcha they smelled really good at times...
                            Dutch
