We did our thanksgiving turkey in the oven last week. I have followed the high heat method for years, so it was quite adaptable to a wood fired oven.
My steps starting the day before :
0. Butterfly the bird. I list this as 0 since it's totally optional, but makes it easier to organize the bird so that all the skin is up (no flipping required) and the breast and thighs get done at about the same time.
1. Brine the bird for 4 hours in 2 gallons of water, 1 cup normal salt, 1 cup sugar. My understanding of the high heat method is that this step is really optional, but I always end up doing it.
2. Rinse bird thoroughly, pat dry, and leave uncovered on a plate with paper towells in the fridge overnight to thoroughly dry out the bird. This step is VERY important for the high heat method.
3. On the day of... start the fire. I actually pre-heated the oven the night before and started a new fire the day of... when the soot burned off the roof and the IR thermometer I borrowed was zeroed out (it only goes to 600 degrees) the oven was about ready. This took about 1 hour to 90 minutes.
I spread the coals to each side and the hearth was about about 570 with the ceiling totally maxed out. Then I piled extra bricks in the mouth of the oven and went to prep the bird.
4. Oil the bird everywhere with your favorite fat (olive oil or butter in our house) and season it with salt, pepper, and any dry rub you might like to use (we used finely chopped fresh sage, rosemary, and thyme).
5. Arrange bird for the oven.
Notes on this step.
Do NOT stuff (not for this high heat method). We arranged the insides of the bird to lay on a rack over a roasting pan full of our stuffing (made up of cubed sourdough bread, hot italian turkey sausage, sage, thyme, onions, celery, some egg and half n half. The drippings all fall into the stuffing.
The skin is up with the thighs floating over the lower breast.
This is the other reason we butterflied the bird. I roasted the backbone and giblets to make drippings, then stock, and gravy.
I've also done this without butterflying, but you don't get the benefit of drippings in the stuffing and have to use the stock for that instead. If you don't butterfly the bird, start it the first half of the cooking time upside down, and then flip it to finish.
The important thing about this fast, high heat method is to avoid stuffing the bird. That is only for slow roasted methods. I like this approach because I always want/need more stuffing than could fit inside ANY sized bird anyway.
6. Cover loosely with foil and place in center back of the oven.
We cooked an 18 pound bird, which in the high heat method at 500 degrees should take 3 hours, 15 minutes.
Since our oven was hotter, I used the foil (normally you don't) and left it on for 90 minutes. Then I removed the foil and returned the bird to the oven. I added a couple very small logs to the red coals on each side at this stage to keep the oven over 500 degrees.
Cook uncovered until the thigh registers somewhere above 150. From experience I recommend between 155 and 160. For our 18 pounder, this was done at 3 hours (a little early due to the even higher heat).
Remove the bird and tent with foil for at least 20 minutes. It will coast on up to the recommended finishing temperatures. This is the time to finish all your other dishes.
I put the stuffing back in the oven to crisp up the top; reheat the gravy; mash the taters (or reheat them if you made them earlier). We also roasted root veggies and squash in the oven with the turkey for the last hour and I left them to finish while the turkey was resting.
Then carve the turkey (carving a butterflied bird is awkward the first time or two because it's basically upside down) and serve!
My 90+ year old step-grandmother-in-law (how's that for a mouthful) told me that she's had a LOT of turkeys in her life and while last years (1 BBQ'ed and 1 rotisseried), this years was the BEST she'd ever had in her life.
I have to admit, I was pretty amazed myself. I can't wait to try lamb.
Notes on this step.
