My 3-Legged Dome
  • fxpose
    • Jul 2009
    • 942
    #166
    Re: My 3-Legged Dome
    Thanks Dino. Actually, about a month passed before I applied my second coat of SBC. The second coat is not completely covered yet. I'll probably do a little more today. As long as I keep the surface free of grime additional layers of SBC will bond properly.
    I've done patch work over old, dirty stucco and they seem to hold up for many years.
    Yes, that's basil, and I agree it's a perfect spot for it. I'll also be potting some vine on the other side so they can climb and create a screen barrier between the oven and the driveway.
    George
    My 34" WFO build
    • fxpose
      • Jul 2009
      • 942
      #167
      I've been applying additional layers of white SBC to the entire dome, a small section at time, as time permits, each morning before going to work.
      George
      My 34" WFO build
      • Tscarborough
        • Oct 2009
        • 3341
        #168
        I really like the way your oven area turned out. It is functional, blends perfectly, and I know you use it often. Thumbs up!
        • fxpose
          • Jul 2009
          • 942
          #169
          Thanks Tom. I've been firing up the oven at least once a week, and since our double wall oven in the kitchen's been out of order for some time now I've been cooking in the wfo often. I really enjoy using the wfo.
          George
          My 34" WFO build
          • mn8tr
            • Sep 2010
            • 116
            #170
            That is a work of art. Great job of matching the oven design to the existing site.
            What type of concrete did you use for the counter top?
            I poured two separate tops and used a high yield strength (pre-mix) and it did not work very well at all. When the forms were removed it looked a little like baby swiss cheese which thwarted my plans of staining the counter.
            • fxpose
              • Jul 2009
              • 942
              #171
              Hi mn8tr,
              Thanks!
              I used Quikrete 5000 bagged concrete mix for the counter. I have yet to polish the surface down and apply finish to it. The counter there has been so functional and convenient that I've been taking time to finish it. Just enjoying the oven....
              George
              My 34" WFO build
              • Alastaire
                Banned
                • Nov 2010
                • 1
                #172
                I have seen the snaps of three legged dome which is shared in post and i really admired its beauty and perfection.
                • Lburou
                  • Dec 2010
                  • 1165
                  #173
                  A very clean design....Demonstrates uncommon skill with ideas and space. Good job! I wish I was as far along.
                  Lee B.
                  DFW area, Texas, USA
                  • scottschmidt
                    • Dec 2010
                    • 5
                    #174
                    George,
                    I'm prepping for a corner install of a 36" Pompeii now...hope to begin construction Feb 1. I'm limited on space..59" total from corner to end before I hit a door. I think I'll be able to make this work...proposed dimensions are (36" + 9" bricks + 6" insulation= 52" + 4" for enclosure).
                    My biggest concern is heat. the walls of the corner are frame/stucco. With your build, what type of heat are you getting off the exterior dome?
                    S
                    • fxpose
                      • Jul 2009
                      • 942
                      #175
                      Excluding the front vent area the rest of my dome exterior never exceeds 10 F above ambient air temperature at its warmest spot. The front vent area above the entry just gets warm to the touch, never hot.
                      You should have no problem with your build as long as you leave enough air space between the dome wall and the house wall, ideally 6" (I read that somewhere). I only have an inch gap at two closest areas.
                      George
                      My 34" WFO build
                      • stephen*z
                        • Jun 2010
                        • 41
                        #176
                        what did you use to attach the vintage bricks to the edge of yout table? I love that look and have collected a nnumber of bricks I would like to use.
                        Steve
                        living in Coastal NC
                        more details of the build at:
                        http://Stevespizzaoven.wordpress.com
                        • fxpose
                          • Jul 2009
                          • 942
                          #177
                          Steve
                          Hi, I used home brew mortar to adhere them as I had an extra pail full of the mix. Regular bagged mortar would have been fine too.
                          Those are not large pieces of bricks, they're 3/4" thick brick ends cut from full bricks. I also scored the inside faces of each brick veneer and the entire surface of the countertop edge so the mortar would grab.
                          George
                          My 34" WFO build
                          • Hank10746
                            • Aug 2011
                            • 43
                            #178
                            Hi
                            This is the third time I have went through your build! This is what I had in mind before I saw it. I cant tell you how impressed with it. I may have missed it but what are the dimensions of the base. I want to build a 36" want to make sure I have enough space for insulation and not hang over. I was hoping to get it in a 48" circle. Any help would be appreciated.
                            Hank
                            • fxpose
                              • Jul 2009
                              • 942
                              #179
                              Originally posted by Hank10746
                              Hi
                              Thanks!
                              My base slab was exactly 48" in diameter. With the decorative brick trim around the base and the finish stucco the overall exterior diameter came out to roughly 50".
                              You'll probably have to go 52" base slab to fit a 36" oven.
                              George
                              My 34" WFO build
