My 3-Legged Dome - Forno Bravo Forum: The Wood-Fired Oven Community
My 3-Legged Dome
  • My 3-Legged Dome
    Thanks for all the valuable information and ideas contained here, including much needed advice from all the great folks here, I finally started my WFO build a couple of weeks ago.
    The 34" oven will be located in a nook just outside of the side door which leads into the kitchen. I will run a 6" stove pipe with spark arrestor well above the roof. Dome walls will be built using bricks cut down to 3" in thickness (as explained in another thread).
    Also, as mentioned in detail in another thread as to the reasons why, the free-standing sonotubed stand simply sits unanchored (except for the pins) over a tiled slab.
    George
    My 34" WFO build
    Re: My 3-Legged Dome
    Form built, supported, and poured:
    George
    My 34" WFO build
      Stand marked, and ready for 3" ceramic board.
      I crumbled up remnants of the fiber board to use as leveler and filler. When crumbled, it turns into cottage cheese. But don't eat it.
      George
      My 34" WFO build
        I really like the dome on pillers look. Will it be "stucco'd" into the corner and look like a corner built-in on stand or will the the dome be it's own "dome" and not tied into the 2 corner walls?
        This is exciting! Your making lot's of progress.
        My Oven Costs Spreadsheet
        My Oven Thread
          I can almost smell the pizza....
            Thanks guys. I will be smelling pizza soon...
            Dino, no, the stucco'd enclosure will be on its own. The oven will not be 'part' of the corner there. I just hope I have enough room back there to shape the dome.
            Here's what I did this morning.
            After chopping the excess I plan on laying the 4.5" high soldier course on top of the floor.
            George
            My 34" WFO build
              Not much progress today except for trimming the brick ends. I bought a cheap 10" masonary cut-off blade and used it on my old 10" compound miter saw to cut the bricks. It seemed to work well using a water spray bottle.
              George
              My 34" WFO build
                That's great the compound saw worked out with the spray bottle. Are you going to use that for all the brick cutting (really asking if you plan on buying/using a wet-tile saw).
                If you're going to keep trying to use the compound saw, remember that we soak the bricks before mortaring so you could pre-soak them BEFORE you even cut them and that should really cut down on the dust (and have them plenty wet for mortar).
                Your floor looks great.
                My Oven Thread
                  Looking good FX..
                  Keep up the good work
                  Mark
                    Thanks guys!
                    I'm progressing in a painfully slow pace. I wish I had a couple of free days completely to myself so I can focus my attention on this project.
                    I'm basically ready to erect the dome. I decided not to use a soldier course but instead lay two courses straight up vertically.
                    Here is a pic of a rather crude indispensible tool that I put together last night. The hinge point revolves 3" around the center axis. The arm length gets reset at the top of the second course and from that point it will trace a slightly smaller arc (15.5" vs 17"), resulting in a lower dome height of about 15.5". Thickness of the plywood base has been account for. Floor radius is exactly 17".
                    George
                    George
                    My 34" WFO build
                      "Here is a pic of a rather crude indispensible tool that I put together last night. "
                      Not crude. "Simple and elegant" is a better description.
                        The cheap abrasive blade wore out quickly and took forever to cut so I got a real blade for the job. ...
                        So I spent a couple of hours just cutting bricks in my driveway next to my clunker....
                        George
                        My 34" WFO build
                          George,
                          Your brick work looks excellent thus far. The I tool looks to be working just fine. Unless you are a professional in the masonry trade, you figure it out as you go. The difference is we think about it about 10x more than people who do it all the time, and make twice as many mistakes. But almost all of us end up with an oven that meets our needs and we are proud of. The brick dust will wash off your clunker- no worries. Looks great!!
                          Eric
                            You're absolutely right about that, Eric. Especially when I get to the dome & vent transition area, it'll get figured out somehow.
                            Thanks,
                            George
                            George
                            My 34" WFO build
                              Yes, the vent/transition area boggled my mind for about a week. But I finally figured it out.
