The build has begun!
  • dvm
    • Mar 2012
    • 242
    #136
    Re: The build has begun!
    Brian the cement arch looks great! With the reveal you left on the outer arch, you could have an outer door if you wanted one.
    dvm
    sigpic
    • brianventura
      • Feb 2010
      • 129
      #137
      Thanks dvm. I do plan on having two doors, an inner and an outer door with a plug for the flue in my attempt to keep in the heat. It may seem to be a little overkill but why stop now. When I finish the stone I will start working on the doors (hopefully I'll finish sometime next year).
      Thanks again,
      Brian
      • brianventura
        • Feb 2010
        • 129
        #138
        I finally have started installing the faux stone on the oven. It will go all around the housing. When I'm finished with that then I will work on the door.
        • ATK406
          • Jul 2012
          • 206
          #139
          Lookin good. I really like the concrete arch....you've got me thinking.
          • fabby
            • Jan 2013
            • 111
            #140
            Your space has to be one of the nicest I have seen. The amount of work you have put in, and the level of skill.......wow.
            (I think I will have to delete all the pictures of my oven and redirect to your build)
            • brianventura
              • Feb 2010
              • 129
              #141
              ATK406,
              Thanks, the arch was the only thing I could come up with where I could end the faux stone. Hopefully it is of some help to you.
              Fabby,
              Thank you for your comment. This project has taken me around 3 years to the point I am at now, 1 year just planning by reading and viewing all the posts I could on this site.
              • brianventura
                • Feb 2010
                • 129
                #142
                The top front is on, now to work on the base.
                • dvm
                  • Mar 2012
                  • 242
                  #143
                  Looks great Brian!
                  dvm
                  sigpic
                  • brianventura
                    • Feb 2010
                    • 129
                    #144
                    I now have the front completed, except for grouting. I'll start on the sides tomorrow.
                    • dvm
                      • Mar 2012
                      • 242
                      #145
                      Nice progress! You have a great blend of colors and sizes stone in the "beauty layer".
                      dvm
                      sigpic
                      • Greenman
                        • Feb 2013
                        • 1123
                        #146
                        That looks great Brian! Your attention to detail and perseverance shines through in the end result.
                        Congratulations, you have every right to be proud of your work.
                        Cheers ......... Steve
                        • okn
                          • May 2011
                          • 133
                          #147
                          Brian,
                          Looks fantastic! You have done a marvelous job! Is the oven door in the picture insulated? If not, are you still getting decent heat retention?
                          • brianventura
                            • Feb 2010
                            • 129
                            #148
                            Thanks you guys. Looks like I will not be done for the Fourth of July this year. I was hoping to be finished with this project last 4th of July.
                            Okn,
                            The door is not insulated. It is just a flat piece of steel. I needed to get something on there because the 2nd wood door was charred. I have not check on the heat retention with the metal door. It has a really good seal but I think it would be better insulated some how.
                            • Texas
                              • Jun 2013
                              • 78
                              #149
                              Did the floor tiles for the kit come cut like that or did you cut them? The kit on the website says the 42" comes with Six 18" x 18" floor tiles and the 36" comes with 4. I assumed they were square.
                              • brianventura
                                • Feb 2010
                                • 129
                                #150
                                Hi Texas
                                The floor tiles did come 18"x18" and I had to cut them. It wasn't too difficult on the saw it just took some time.
                                I apologize for not getting back to you sooner, I have been out of town.
                                Brian
