The build has begun!
Hello Ivan, thanks for the compliment. Yes the soldier course does have an angled cut. I placed the bricks down on the ground to the angle of the arch and decided on a random angle that looked good to me. I cut the brick and decided that angle would work. As for the degree of the cut I do not know what it was I just set the saw up to the angle of the original brick and cut the rest. I hope this helps you and good luck with your build.
Brian1 PhotoComment
Great work very impressive!! I also used a full soldier course and I am debating on reinforcing with cement just as you did. Definitely like the idea of the bracket supports on your arch.Re: The build has begun!
Thanks Cheesesteak,
Here are some more photos. To support the soldier course I poured concrete around them. It's just a little piece of mind since I have a tall soldier course and I have read that they do need to be reinforced so they don't get forced outward.
thanks for a well documented build.
IvanComment
Breakfast pizza for Memorial Day. The photo was taken before I put fresh basil on top. Delicious!!1 PhotoComment
Looks very good...I'm going to have to try making one someday.My Build Pictures
https://onedrive.live.com/?authkey=%...18BD00F374765DComment
BV,
It has been a long time no see. Glad to see you post a M-Day pie.Comment
Hi, thanks for remembering. It has been awhile. No changes on the oven and it is working perfectly. The only disappointment is that I don’t use it as much as I would like.Comment
