Re: Down Under Brick Dome Build
Hi CM
Your oven's looking good. You're not far off pizza now.
I think every arch to chimney transition is different. You have to build a flat square structure on top of the arch and that makes for some of the most difficult cuts in the whole build. I looked at lots of pictures of other builds, and then did something different anyway.
Where did you buy your chimney cap? Is it an 8 inch?
Hi CM
