The Backofen
  • #16
    Re: The Backofen
    Originally posted by Coloradoredusa View Post
    Thanks guys .. I am on my way to HD to get the materials for the IT and a new saw blade. will post progress this evening .. thanks again!
    I see the Kissing Camels in your signature! Lived one mile from them for 15 years, lots of good memories rock scrambling with my grandchildren.
    Lee B.
    DFW area, Texas, USA
    • #17
      Re: The Backofen
      Originally posted by Lburou View Post
      I would not taper my bricks again. It was a lot of effort with little return. Also, I would not attempt a tiny mortar seam on the inside of the oven (that makes it impossible to completely chink the openings between the bricks with mortar. At least one forth inch of mortar between bricks has worked fine in many a good build. Those are a couple of my observations in hindsight, I hope they are useful to you.
      I agree you can get a good build either way. My suggestion to taper was based solely on the use of HS50. At $80-100 per bag, the return on tapering is that mortar goes much further. If you are using homebrew then the cost vs. time equation is less compelling.
      • #18
        Re: The Backofen
        I wasn't trying to be mean, just reiterating my thoughts. Thoughts we discussed on the telephone, and were not pointed at your remarks deejayoh.
        Lee B.
        • #19
          Re: The Backofen
          no worries. I didn't take your comment as mean or critical in any way. apologies if my remarks came across as defensive. It's all good conversation
          • #20
            Re: The Backofen
            here is the photo of the brick..lemme know..
            “Never regret. If it's good, it's wonderful. If it's bad, it's experience.”
            Trellis
            Home Sweet Home~ Colorado Springs ~
            sigpic
            • #21
              Re: The Backofen
              Ummm. yeah.. that didn't work.. I guess I need to find a bag of fire clay..I had too much sand and not enough clay.. wont post any pictures of that fiasco..
              any suggestions?
              Trellis
              sigpic
              • #22
                Re: The Backofen
                That looks right for the cuts.
                You might want to use a herringbone pattern on your floor so that you don't have bricks perpendicular to your peel.
                any suggestions?
                Cut a bunch of your sailor bricks and you will have plenty more wet fireclay. Just clean out the saw tray.
                • #23
                  Re: The Backofen
                  How thick does the bed need to be?
                  On the herring bone pattern.. aren't there going to be ridges on that even when its tapped into the clay?
                  Trellis
                  sigpic
                  • #24
                    Re: The Backofen
                    Thick enough to level the bricks used for the floor only. If they are flat without filler, you don't need it.
                    Lee B.
                    • #25
                      Re: The Backofen
                      Thanks Lee Thanks DJ... will be cutting a mess of bricks tomorrow again!
                      Trellis
                      sigpic
                      • #26
                        Re: The Backofen
                        Did you use a square notch trowel to trowel it out? It only needs to be as thick as the grooves. 1/4" maybe?
                        • #27
                          Re: The Backofen
                          Yah.. bought the same one at Ace.. I'll see how it goes tomorrow..
                          My head hurts now..LOL
                          Trellis
                          sigpic
                          • #28
                            Re: The Backofen
                            Hah. I haven't been able to work on my oven since Sunday night. Pulled off the tarp and looked at the last three bricks I laid, and they looked horrible. None of them lined up. I wondered if I had been drunk when I put them in and just forgot that part. Ended up knocking them out with a cold chisel.
                            Sometimes it's one step forward, two steps back.
                            • #29
                              Re: The Backofen
                              so I cut a bunch of bricks at a 7 degree angle today .. question.. on the sailor course, when i do set them in HS50 do I stagger the mortar joints on the second course? Do I cut the the second course with the taper 7 deg? Or do I do whole half brick?
                              Trellis
                              sigpic
                              • #30
                                Re: The Backofen
                                I did a mock-up of the arch..14 inch door opening 9 inches from the floor..
                                should I put a tapered brick in the center ?
                                Trellis
                                sigpic
