Re: 42" FB Pompeii Oven with 19" dome, and adjacent fireplace, in the O.C.
One advantage of a low dome oven is the fact that you can built you soldier the same height as your door. At that point tying the two together at the top is as simple as bevel ing the angles to match.
On the flip side I would not personally consider 18" to be a low dome oven, and using my method would not work well due to the taller door.
Just thought I would chime is since I have built two low dome ovens and can give a good amount Of guidance on them that others cannot.
The entire structure includes the pizza oven base, an adjacent fireplace, a inserted gas grill, with side counters and small fridge, and a pony wall for seating.
Hi John
. I think most people use a couple layers of luan for the arch forms. It's a bit stronger than the flashing.
