New Build Oven At Granite Falls
  • man7sell
    • 88
    #16
    Re: New Build Oven At Granite Falls
    Boy miss counted here, my opening is too small. 2 soldiers removed and the entrance rebuilt. That's better, bigger pizzas
    Capt. Paul
    Granite Falls WA, USA.
    Oven In Granite Falls
    • man7sell
      • 88
      #17
      Second course laid, these are all wedge shaped to start the roof line.
      Third course much less of a wedge and sides cut to go around the circle. The remaining bricks will have a slightly shallower wedge and progressively more of side cut angles as the dome climbs. These are all hand laid. Need to decide on which system to use to finish the rest of the brick courses.
      Capt. Paul
      • deejayoh
        • Jul 2010
        • 1893
        #18
        Looking good. Curious about where you found the 12 x 12 firebrick tiles? I looked for something like that locally (I am in Seattle) and could not find them
        • man7sell
          • 88
          #19
          Found them at Harbison-Walker Refactories in Kent.
          19817 8th Ave S Suite D
          Kent, WA
          2538722552
          Manager's name is Daniel.
          They were $20 a piece. They have larger but get exponentially more as they get bigger.
          Capt. Paul
            Originally posted by Tscarborough
            If you do the calculation for the weight of a full brick oven from the hearth up, you will find the required PSI of the hearth slab to be incredibly low. Factor in where the majority of the weight is (the perimeter), and a solid 2" slab will probably be fine. Add another 2" if you want, it won't hurt anything.
            Actually Tom, if you study it a bit more carefully you find that the heaviest part of the oven is not at the perimeter, but somewhere closer in. For this reason I believe that a cantileverd stand, under the supporting slab is a stronger solution. Ultimately is doesn't really matter so long as the thing is strong enough so it doesn't fail.
            • man7sell
              • 88
              #21
              Well to be safe, I've installed an adjustable steel building support post and a large steel disk on the top of the post (It was laying around the property so perfect and free). The post will not really get in the way of the wood storage.
              Capt. Paul
              • Tscarborough
                • Oct 2009
                • 3341
                #22
                Since the perimeter of the oven is the only thing that touches the hearth, it is the only place were there is ANY weight, other than the brick of the floor (and the perimeter of the hearth slab will have weight if there is an enclosure).
                  Yes true, I was thinking of an igloo which has very little mass outside the inner dome.
                  • dvm
                    • Mar 2012
                    • 242
                    #24
                    man7sell
                    How goes the build?
                    dvm
                    sigpic
                    • man7sell
                      • 88
                      #25
                      I was trying to do an update using photobucket today but the site's not working correctly today. I will try from another computer
                      Capt. Paul
                      • man7sell
                        • 88
                        #26
                        Huh, must be my other computer's java is out of date. Works from my MAC Update to come.
                        Capt. Paul
                        • man7sell
                          • 88
                          #27
                          Made a version of the indispensable tool (IT) for the dome build. Used hardware from Home Depot and stuff I had laying around. Works great and is fully adjustable. Up to the third course now. At this point it is time to build the entranceway to allow the intersection of the dome to tie in with the entrance.
                          Each brick gets cut 3 ways to radius the dome and create to dome profile.
                          Here's the IT made from a castor wheel I had and a piece of threaded rod. (Never throw anything away right?).
                          OK, don't get a photo of me everyday, usually the one taking the photos.
                          Capt. Paul
                          • ShannonCorum
                            • Jul 2012
                            • 26
                            #28
                            Did you use 5000psi concrete or something equivalent? My hearth is about 3 1/2 thick. But I know very little about how much weight concrete can hold. I do have rebar in mine. Quite a bit. Your cinderblock structure looks great! I like the concrete pad underneath. Will make your area very clean looking.
                            • man7sell
                              • 88
                              #29
                              No idea what the strength rating of the concrete is. Rebar should support the load.
                              The concrete pad underneath was the work of my next door neighbor out there. He was really good at it. Later we will add mosaic tile on it to match whatever design we come up with for the oven
                              Capt. Paul
                              • dvm
                                • Mar 2012
                                • 242
                                #30
                                Looks like good progress. Are you planning a spherical dome or something lower?
                                dvm
                                sigpic
