Starting a 30" Pompeii oven in Minneapolis
  • gastagg
    • May 2013
    • 271
    #16
    Re: Starting a 30" Pompeii oven in Minneapolis
    Got the forms for the stand done. Ran out of time to pour the stand tonight. Will get it tomorrow.
    George
    See my build thread here.
    See my build album here.
    • mrchipster
      • Apr 2010
      • 1502
      #17
      Looking great. Very interesting shape. I cannot wait to see it standing on it's own.
      Chip
      • gastagg
        • May 2013
        • 271
        #18
        Well, I got the stand poured today, barely. Following the advice of my architect brother and a civil engineer friend, I rented a concrete vibrator. After pouring about 1/2 the concrete, I started to vibrate the concrete and the forms started to blow out where I was vibrating. You can see the pics. Once I removed the vibrator, everything was fine. I added some additional braces and finished the pour. A little bulging here and there with the hardboard as you can see. I used a mallet to vibrate the forms once I was done to remove air pockets.
        If I did this again, I'd obviously use thicker boards, add more braces, and have my civil engineer friend perform what he calls a "form inspection" before the pour. But at this point, I am just thankful that the forms held and that that the concrete is level and setting.
        George
        • mrchipster
          • Apr 2010
          • 1502
          #19
          Interesting thing about engineers, they think everything needs to be built to the code/specifications of something much larger/stronger/faster than the actual thing being built. Which is something that has stood over a thousand years with little or no mortar in a volcanic earthquake zone and built by people who knew nothing about mathematics and had no concrete or vibrators.
          A Pompeii oven.
          Btw I am glad it held.
          Chip
          • gastagg
            • May 2013
            • 271
            #20
            Well I can't blame them...I should have built more bracing. But as you said, glad it held!
            George
            • mrchipster
              • Apr 2010
              • 1502
              #21
              It's just that the vibrator was overkill for the project, you already had reinforced 5 inch walls....
              Chip
              • gastagg
                • May 2013
                • 271
                #22
                Can't argue with you there. And it cost me $40 to rent too!
                George
                • gastagg
                  • May 2013
                  • 271
                  #23
                  Took the forms off today...am pleased with how it turned out. One one more concrete pour to go!
                  George
                  • mrchipster
                    • Apr 2010
                    • 1502
                    #24
                    Place a waterproof layer between the lower section and the next slab. It will prevent any moisture for wicking from below.
                    This is one of the things I should have done but read about it after my slab was poured.
                    Chip
                    • gastagg
                      • May 2013
                      • 271
                      #25
                      Thanks for the recommendation! Will definitely do that.
                      George
                      • gastagg
                        • May 2013
                        • 271
                        #26
                        Thanks for all the help so far. I am planning slab dimensions that the oven will sit on. Am trying to increase the size of my oven by 2" (30" to 32"). I have been planning 3" of blanket insulation. Am doing igloo so won't have any other insulation. Is 2" of 8# density thermal blanket enough and just keep the size of my slab the same, or do I need to go ahead with 3" of blanket and increase the size of my slab?
                        George
