36" Vancouver Island build
  • ubcpsyc
    • May 2018
    • 44
    Hi there,
    I have been a silent member on this site for a while and thought I would post my progress. Brutal honesty and recommendations welcome!
    This project has been a fantastic journey of learning.
    I'll try to add it details as I post.
    As a disclaimer I have never worked with concrete but I did spend a lot of time studying before I dove in.
    Pic 1: dug deep to get to something solid for the base. The chickens were excited about this event...
  • ubcpsyc
    • May 2018
    • 44
    We then put down fill and impacted
    • ubcpsyc
      • May 2018
      • 44
      I wrote some captions on the photos but here is the base going in
      • ubcpsyc
        • May 2018
        • 44
        Cinder blocks going in!
        We figured out all the spacing ahead of time. I used graph paper to figure out where to put the rebar.
        • ubcpsyc
          • May 2018
          • 44
          Some finishing touches for the back splash
          • ubcpsyc
            • May 2018
            • 44
            We spent a lot of time doing the framing for the countertop. I had seen a few where the boards got pushed out during pouring!
            • ubcpsyc
              • May 2018
              • 44
              Here is the finished counter top!
              • ubcpsyc
                • May 2018
                • 44
                Finally the dome got started. The weather is now better than in December and we can see the view!
                • ubcpsyc
                  • May 2018
                  • 44
                  Looking at how the chimney will fit. (only 6" double walled).
                  • ubcpsyc
                    • May 2018
                    • 44
                    I ended up using an exercise ball to support the final layers. I covered the outside with refractory concrete to seal any holes and increase the thermal mass (rightly or wrongly!)
                    Once the key stone was in we removed the ball and thankfully the whole thing didn't collapse..
                    • Unknown_element
                      • Jun 2018
                      • 12
                      Looks great!
                      • ubcpsyc
                        • May 2018
                        • 44
                        Thanks! Still trying to figure out how to get the chimney in!
                        • agrasyuk
                          • Jun 2016
                          • 107
                          found your build thread, indeed you using a metal pipe and not flue liner )
                          it looks like your stand does not allow for very think cladding around the dome. be sure you don't skimp on at least some sort of insulation, ideally blankets, even if it means it will be overhanging. the metal mesh should support the relatively lightweight layer of peri\Vermicrete on top of the blanket.
                          the view from your yard though... wow.
                          good luck!
                          Anton.
                          My 36" - https://community.fornobravo.com/for...t-bg-build-log
                          • ubcpsyc
                            • May 2018
                            • 44
                            Thanks for the reply. I am planning on 3 layer of 1" ceramic blanket followed by 10:1 perliteortland cement. I like your idea of the funnel! I'm going to try and interoperate that idea and will post some pics. Thanks!
                            • SAG
                              • Apr 2014
                              • 2
                              I am planning a build on denman island but having difficulty sourcing ceramic fiber board. Did you have any luck?
