Re: Hansen Horno
I think it's worth it - but with some mod's. Forget about the back - mortar is your friend. I cut mine in half - then focused on the side taper and vertical angle, believe me, that's enough. I tried to cut an entire course at once but it was not meant to be - the accuracy of your cuts will bite you in the end. You will have to make custom cuts about every three or four bricks. That was my experience. If you had a compound brick saw it would probably be a slam dunk - I bought what most have - the Harbor Freight. One more area of pain - when you get to the 10th or 11th course, the bricks become so narrow it's a bitch to hold them steady - again, it's all in the saw.
Les...
Originally posted by dbhansen
View Post
Les...
