I'm running across quite a few misdirected and or broken links. Is this the best place to report them and will they get fixed or are they another casualty of the "upgrade"?
Issues with New Forum
This is a sticky topic.
Mitch, I've ran across quite a few. Maybe I should start a new thread "Broken/Missing Links? I see two advantages - a bunch of such reports will fill this thread up quite quickly, and a separate one might make it easier for others to see if the one they found has already been reported. Let me know what you think.My build thread
https://community.fornobravo.com/for...h-corner-buildComment
Dear Forum Members:
The issue with hyperlink misdirects has been resolved. We ran a script to correct all the broken links ending in ####-####.html
Eg.: http://www.fornobravo.com/forum/8/gu...ld-7051-4.html
The bulk re-direct process initially used for re-directs was dropping the dash and not recognizing the update. We simply ran a script to identify errors and update the link as needed.
Mitch
Forno Bravo👍 1Comment
David, Mitch,
I've also seen it a couple of times. I think that it is designed to help keep the spambots
out of the forum
Last edited by Gulf; 10-26-2015, 04:09 PM.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
After the forum did it's reset today (11-16) I am having trouble with my posts. I attached 4 photos, but when I look at the post it has grabbed some random pictures that are not the ones I posted, and one of them is not even on my hard drive. Also, less important, I was in the mid 150's for number of posts and it has reduced my count somehow.My build thread
I found out where my missing posts are missing from. The new membership levels thread had several comments by me and others about Gulf and UtahBeehiver becoming member-moderators. Those posts have all disappeared. Hopefully other posts were not similarly affected.
Nevermind, I see the forum knows it has some posts that are missing - hopefully they will be found...Last edited by JRPizza; 11-16-2015, 04:53 PM.My build thread
Moving over to here so as not to fill up my build page - I cleared my cache and the poltergeists seem to be appeased. All my photos are appearing as they should.My build thread
https://community.fornobravo.com/for...h-corner-build👍 2Comment
To clarify for Forum members: if you are having a similar issue with images, clear your cache and the issue should resolve.After the forum did it's reset today (11-16) I am having trouble with my posts. I attached 4 photos, but when I look at the post it has grabbed some random pictures that are not the ones I posted, and one of them is not even on my hard drive. Also, less important, I was in the mid 150's for number of posts and it has reduced my count somehow.
Thanks,
MitchForno BravoComment
