Issues with New Forum
This is a sticky topic.
  • #76
    I'm running across quite a few misdirected and or broken links. Is this the best place to report them and will they get fixed or are they another casualty of the "upgrade"?
    My build thread
    • #77
      Yes, you can report them here and I will follow up and find out if the link can be fixed. Please be as specific as possible as to the location of the link in question.
      Mitch
      Forno Bravo
      • #78
        Mitch, I've ran across quite a few. Maybe I should start a new thread "Broken/Missing Links? I see two advantages - a bunch of such reports will fill this thread up quite quickly, and a separate one might make it easier for others to see if the one they found has already been reported. Let me know what you think.
        My build thread
        • #79
          Great idea!
          Forno Bravo
          • #80
            Dear Forum Members:
            The issue with hyperlink misdirects has been resolved. We ran a script to correct all the broken links ending in ####-####.html
            Eg.: http://www.fornobravo.com/forum/8/gu...ld-7051-4.html
            The bulk re-direct process initially used for re-directs was dropping the dash and not recognizing the update. We simply ran a script to identify errors and update the link as needed.
            Mitch
            Forno Bravo
            • #81
              Sometimes when typing a post I get a message asking me to verify that I'm human. What is going on here?
              • #82
                Hi David,
                I'll look into the human verification issue.
                Mitch
                Forno Bravo
                • #83
                  David, Mitch,
                  I've also seen it a couple of times. I think that it is designed to help keep the spambots out of the forum .
                  • #84
                    "Sometimes when typing a post I get a message asking me to verify that I'm human. What is going on here?"
                    Originally posted by fbfireoven View Post
                    Hi David,
                    Mitch
                    Ok, I thought maybe you've been talking to my wife.
                    • #85
                      After the forum did it's reset today (11-16) I am having trouble with my posts. I attached 4 photos, but when I look at the post it has grabbed some random pictures that are not the ones I posted, and one of them is not even on my hard drive. Also, less important, I was in the mid 150's for number of posts and it has reduced my count somehow.
                      My build thread
                      • #86
                        I found out where my missing posts are missing from. The new membership levels thread had several comments by me and others about Gulf and UtahBeehiver becoming member-moderators. Those posts have all disappeared. Hopefully other posts were not similarly affected.
                        Nevermind, I see the forum knows it has some posts that are missing - hopefully they will be found...
                        My build thread
                        • #87
                          We are working on restoring the missing posts and I have reported the issue you are having with images. I'll keep you updated as I receive information!
                          Mitch
                          Forno Bravo
                          • #88
                            Moving over to here so as not to fill up my build page - I cleared my cache and the poltergeists seem to be appeased. All my photos are appearing as they should.
                            My build thread
                            • #89
                              Mine seemed to be working right today. But, I just cleared the cache anyway.
                              • #90
                                To clarify for Forum members: if you are having a similar issue with images, clear your cache and the issue should resolve.
                                Thanks,
                                Mitch
                                Forno Bravo
