Hi All
I'm new to this forum, but have been reading posts on this forum for a while now. I've been so impressed with everyones different projects, ideas and Ive learned from you all. So I'd like to thank everyone for inspiring my build. There are lots of you out there that have built some fantastic ovens both indoors and outside and have experienced how the oven functions. I have a few questions which some of you have experienced. I am much obliged if any of you can answer some of my questions below.
Im building a Hobbit house in my garden, it's round building with a semicircular dome, basically the same as a huge pizza oven. The inside is a brick facade and the outside is in granite. Inside the domed walls of the Hobbit house i'm constructing a Napolatian style oven with 106 cm diameter.
I decided to build Napolation oven with a lower flatter dome. This required two radius's for the dome; a steeper first five courses on top of the soldier course; thereafter a flatter radius to the centre. There is more outward thrust for this type of dome shape, however, in my opinion a circular dome is also not stable without some form of buttressing, so I have incorporated a buttress harness. A catenary shaped dome or arch is actually most stable but wouldn't suit a pizza ovens design, read more here https://en.wikipedia.org/wiki/Catenary. Basically an inverted hanging chain which is the same length as the centre line of an arch/dome cross section, represents the line of thrust upside down. This invisible upturned line of thrust should lie in the middle third of the brick or voussoir, if it does not, then the arch/dome will be unstable without buttressing. This is why the gothic arch revolutionised spanning wider openings with less stone. Before this the Roman half circular aches and domes required higher/larger voussoirs to bridge wider openings, which meant that there was a certain limitation spanning wide openings.
I started the build on the 6th August and set the last keystone on the 16th August, so it's taken 10 long days of work to get this far. The first five courses where all cut to a steeper radius, however i only tapered the correct radius of the bed joint, not the perpendicular joints of these first five courses. After the first five courses, with the flatter arced dome, all the four sides of the brick voussoirs were cut to a different trapezoid for each course for tight fitting.
I have mixed my own mortar which is from clay / hydraulic lime / sand. There is no cement, both the hydraulic lime and clay is the binder with the sand. The hydraulic lime helps to harden the mix. Since cement was first patented in 1824 all ovens before this had no cement in the mortar. Hydraulic lime is a more flexible binder than cement and allows for for movement through thermal expansion. The joints inside the dome are 2-3 mm.
Now that the dome is completed, the next job is to build the vent and construct the chimney etc. There will be a heat break between the entrance to the dome which will be 10mm air gap sealed will fire rope. The hearth entrance to the inside of the dome entry arch is 60 cm. The pizza oven is built into the wall of a 9m² room.
Questions;
1. If the oven does not have a door, how will the radiating heat effect this small room when the oven is in full operation, will the room become unbearable to sit in without a door which can be closed? The door would have to be on the room side of the vent/chimney. I will have an insulated door for heat retention and longer cooking but this cannot be used to stop radiating heat into the room because it also blocks the vent. I'm wondering whether it's worth designing a door which can be closed within the rooms facade? If anyone advises to have a door then I need to incorporate this in my design, otherwise i might regret it later. Has anyone else built an interior oven who can tell me how hot it can get within the room?
2. Another question is insulating the dome. I thought that i would parge the dome first with clay / hydraulic lime / sand mix 2-3 cm thick to seal the dome (perhaps some chicken wire too). Thereafter, covering with 7cm of insulating concrete made with Leca / Hydraulic lime / clay. This will be a loose fairly dry mix with air voids. The rest of the enclosure will be Rockwool masonry insulation, this is slightly harder than normal rockwool. These materials are readily available to me.
Basically the clay parging firstly seals the dome; the Leca insulating concrete separates the Rockwool from the direct heat. Any thoughts on this?
I will post some more of the build at a later date
Questions;
). I prop my doors at an angle to achieve variable dampening for the fire as needed.
. Would these vents be built with some sort of closure? So they could actually be used control/dampen the fire as needed.
). Since I've joined this forum, I find myself more and more fascinated with any architecture that has features of an arch or dome...I don't know if I should admit that since I got my Masters degree (40 years ago!) as a fisheries biologist.
