Hi Mike,
I'm going to go for fabricating the door myself. I think i'll make a steel rectangular box/envelope, which I will build in-between the chimney/vent and the rooms facade and positioned above the arch. A "U" shaped metal channel from the box/envelope down to the hearth floor will be built between the Vent /chimney area and the rooms brick facade providing a slot for the door to slide in. The door can then be hoisted up into this box/envelope and not be seen. I'll have to work out some sort of simple hoist system which won't need any maintenance (once built in I won't be able to get it out again). I think I'll also cut out for a glass window in the door, so if closed you'll still see the fire.
I found these closable vents which I can build in either side at the bottom of the vent area.http://josefdavidssons.se/produkt/ac...-2-en/?lang=en
All this will take a while to fabricate, but it means that I can continue with my vent chimney construction due to the door being mounted between this and the rooms facade. Thanks to your advise about soot, it made me rethink putting the vent between the rooms facade and chimney/vent. Really grateful for your input Thanks.
Chris
Chris
or have live coals drop down under your structure
. Would these vents be built with some sort of closure? So they could actually be used control/dampen the fire as needed.
). Since I've joined this forum, I find myself more and more fascinated with any architecture that has features of an arch or dome...I don't know if I should admit that since I got my Masters degree (40 years ago!) as a fisheries biologist.
. I'm looking forward to following your progress. No matter how long it takes lol.
