Fire Brick Size?
  • Derkp
    • Apr 2010
    • 188
    Fire Brick Size?
    Hi,
    We have quite a few fire brick that are 2.5-7"X5X18 long, also our design is almost all exact dry fit.
    How much mortar is required if the bricks fit tight?
    Anything that I should know about using such large bricks in the hearth and back wall?
    Derk
  • Raffy
    • Sep 2008
    • 213
    Re: Fire Brick Size?
    Using large brick is actually good for the hearth. The less seams the better for cooking since the the hearth/floor is the surface where the food will be cooked. If your brick is 5 inches thick then you'll have more thermal mass than most other oven's built with the FB Pompeii Plans. Standard firebrick is around 4 inches thick you see but I don't see any problems with that. Worst consequence is that it will take you a few minutes longer to heat up the floor.
    sigpic
    Raffy's WFO Build Thread
    WFO Build Pics (Picasa)
    • Derkp
      • Apr 2010
      • 188
      Thanks for the help.
      I remeasured my brick and it is 4 1/2 inches thick. It is also new firebrick from a scrapped steel factory, they had many, many, many thousands of different sizes. The company selling it said it was good for 3000 degrees F. We are planning on a 27X41 oven floor with a 14 inch arch height. We are designing a barrel oven. Does anything sound funny with those numbers?
      Thanks for your advice.
      Derk
      • Tscarborough
        • Oct 2009
        • 3341
        With a 14" arch height, your opening will need to be around 8.75 to 9 inches tall. That seems pretty low. My barrel vault is 22"Wx36L" long, with an dome height of 22" and an opening of a tad over 13".
        • Derkp
          • Apr 2010
          • 188
          I am still in the dry fit, see what size I really want stage.
          Are there any other critical measurements that I need to be aware of before I start mixing cement?
          I could just add a brick or two to the arch and opening and I could come close to your measurements. Does it draw ok?
          I have ordered all of the most popular and recommended books through interlibrary loan to get all the knowledge I can before I start.
          I will try to post a few photos this evening of what I have to work with.
          Thanks again,
          Derk
          • Tscarborough
            • Oct 2009
            • 3341
            One match fire start and not a whiff of smoke out the front.
            • Derkp
              • Apr 2010
              • 188
              Is the bottom of the flue pipe at the inside height of the dome or the opening?
              • Tscarborough
                • Oct 2009
                • 3341
                • Derkp
                  • Apr 2010
                  • 188
                  Thanks !
                  That is the picture I have been looking for!
                  Did you use regular mortar to full in the space or Refractory?
                  • Tscarborough
                    • Oct 2009
                    • 3341
                    Home brew refractory. Link in sig has all the pics.
                    • Derkp
                      • Apr 2010
                      • 188
                      More great pictures. Thanks
                      Is this order correct:
                      Block stand
                      30X30 slabs--concrete?
                      Perlite/concrete insulation layer?
                      Thin layer of mortar to set firebricks
                      oven floor
                      I have seen a few designs that have an isulating layer recessed in the top cavity between the blocks, a layer of cement that spans the blocks and then oven floor.
                      I am about to get serious but I am still looking for fireclay to make my own homebrew. So far $29.00 to ship a $15 dollar bag,50 lbs.
                      Derk
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        Have you googled masonry suppliers for your area?
                        Yes, I had some old 30x30x2 inch pads I used instead of placing a slab, then 4" of perlcrete, a mortar leveling bed, then the floor.
                        • Derkp
                          • Apr 2010
                          • 188
                          I have found a few ceramic/pottery places I am going to try tomorrow. There seems to be different types of fireclay. Is your percrete pad sturdy? Hold the weight well ? Compress? There seems to be many approaces to slab, insulation, floor percrete combinations.
                          • Tscarborough
                            • Oct 2009
                            • 3341
                            Ceramic/pottery places around here charge $9.50 for a firebrick while the masonry supply houses charge a buck fifty for the identical unit.
                            The compressive strength of 8-1 or even 12-1 is more than adequate for this application. There are many ways to skin the cat, but the purpose is to build a thermal mass, highly insulated.
                            • Derkp
                              • Apr 2010
                              • 188
                              Tom,
                              What was the recipe for your home-brew fireclay mortar? there seems to be many skinned cat ideas on this also.
                              I have found fireclay (dry) here in Salt Lake. It is about $16.00 per 55lb but no shipping.
                              Derk
