Fire Brick Size?
  • Tscarborough
    • Oct 2009
    • 3341
    #16
    Re: Fire Brick Size?
    Sand, lime, fireclay, cement, 3:1:1:1 for the brick seems to be best (I used pre-mixed), and a little different for the area around the flue.
    • Derkp
      • Apr 2010
      • 188
      #17
      I ordered one bag of refmix from a retailer in CA and now have a fireclay supplier in SL so I will use the Refmix for the joints on the arch, fireclay and sand for oven floor bed and your mix for flue? and odds and ends.
      Derk
      • Derkp
        • Apr 2010
        • 188
        #18
        Sorry,
        Which pre-mix did you use?
        • Tscarborough
          • Oct 2009
          • 3341
          #19
          Able Refractory cement out of Houston. It is an air-set water soluble, not recommended for exterior use.
