Oven Build 900mm - NZ
  • kriso
    • Oct 2010
    • 62
    #31
    Re: Oven Build 900mm - NZ
    John
    Thought that I had stuffed up on the lime part, however the lime that Farmlands sells is hydrated lime. Went to the web site of McDonalds lime (McDonald's Lime | ONLIME | Home).
    Hydrated Lime Ca(OH)2
    Calcium Hydroxide Ca(OH)2
    Common Names: slaked lime, hydrated lime
    Available in Bulk or 20kg bags
    They sell these at farmlands for $9.00 a 20kg bag.
    I did some other checking on the horticultural lime which is CaCO3 (calcium carbonate) which will not work as you said like the hydrated lime Ca(HO)2 (calcium Hydroxide).
    Glad that I double checked it and hopefully any others can benefit from this info.
    Kriso
    • kriso
      • Oct 2010
      • 62
      #32
      After finally getting all the info on the lime front I have a better understanding between Hydrated lime (Ca(HO)2 calcium hydroxide) and horticultural lime (CaCo3 calcium carbonate).
      I have just laid the first layer of firebrick for the base......
      • wemme
        • Dec 2009
        • 78
        #33
        That's looking pretty smart Kris,
        cheers for all the lime info guys.
        http://www.fornobravo.com/forum/f2/o...-nz-14012.html
        • kriso
          • Oct 2010
          • 62
          #34
          Hi there all
          Can anyone give me an answer to what the reason is behind the soldier course or first corse.
          I have attached some pic of the options I am pondering.
          I have just laid the floor tiles. The bricks I am using go outside the floor tiles and thus the first corse of brick is only 50mm. Should I lay the first course on its side to give it extra height. Should I lay a second layer straight up which will give a vertical of 125mm or just start the curve from the 50mm.
          Cheers Kris
          • brickie in oz
            • 3445
            #35
            Originally posted by kriso
            Hi there all
            Its to achieve some height before the dome starts.
            Also, your black house bricks wont last 5 minutes in a pizza oven, Ive laid similar on houses and they are rubbish.
            • kriso
              • Oct 2010
              • 62
              #36
              Thanks brickie in Oz
              I am glad that I did not lay the first corse today. I was tempted to but thought that it could wait till tomorrow. It sucks that they are no good as bricks here in Rotorua are hard to come by, fire bricks are $7 each. I found some clay pavers would these do the job????
              Kriso
              • John French
                • Oct 2010
                • 56
                #37
                Hi there all
                Cheers Kris
                It is to gve hieght and hence workable space. However, some avdvocate not using soldier coursse but go striaght nto half bricks on the bases. I choseto go the cut down soldier route with a 22deg angle cut across the top. This ave hieght aand a traditional profile but a go head sart in terms of angling the next courses of the dome
                • brickie in oz
                  • 3445
                  #38
                  I laid clay pavers as a first course skirt in my oven and they seem to be standing up to the heat, the only thing that has cracked in my oven is the fire brick tiles I used for the oven floor..?
                  Search for "Johnny the oven man" on this forum, he knows all his stuff and is here in Melbourne.
                  Maybe you could do a castable oven as I did, it might be cheaper?
                  • kriso
                    • Oct 2010
                    • 62
                    #39
                    Thanks John
                    I have just received a email from Brickie in Oz who informed me that the clay bricks that I have will not last at all. I am going to go to get some clay pavers tomorrow. Have you used these and do you think they will work.
                    Kriso
                    • wemme
                      • Dec 2009
                      • 78
                      #40
                      I'm just going to start straight into the dome.
                      Picked up hydrated lime from Place makers.
                      Just need to organise a diamond blade and can start.
                      Regards
                      Bart
                      • John French
                        • Oct 2010
                        • 56
                        #41
                        I bough firebricks - these are expensive in NZ but given the overall cost and effort going into the project i decided not to risk using bricks which will spall in the extreme heat of the oven.Not sure of suppliers in the North Island but they may be cheaper than in Soutn Island. Cheapest quote in Chch was about $5 per brick, although I did a deal with the supplier @ $4-50. Still a lot when using c 200 bricks
                        • wemme
                          • Dec 2009
                          • 78
                          #42
                          Hey John, I'm also using the bricks from Canterbury clay bricks. I'm still curious how well these will preform. did you have some crumbly ones?
                          Regards
                          Bart
                          • John French
                            • Oct 2010
                            • 56
                            #43
                            Regards
                            Bart
                            Hi Bart
                            i think all firebricks are pretty brittle and crumbly. However, the ones i am reluctant to use are those with significant cracks running through the brick. I worry that these will fail in the oven lead to lack of structural integrity.
                            • kriso
                              • Oct 2010
                              • 62
                              #44
                              Bart
                              Do you have any of your fire bricks left over and if can I buy some off you.
                              Kris
                              • wemme
                                • Dec 2009
                                • 78
                                #45
                                Hey Kris. My old mans already put dibbs on my left overs as he is building an oven after mine. see how mine goes first... besides these are not the greatest and wouldn't think they would travel well also at about 3 to 4 kg each I think it would cost a heap to send up to you... I'm just sending you this from my phone but will send you a link to a book that tells you how to make an oven some brick for the base but the rest From clay
                                Regards
                                Bart
