i'm planning a build in CA. probably a 36". i've worked a little w/ stone and metal before. i've been lurking and reading, but i still have a couple details i'm unsure of, if you don't mind.
i live near enough FB HQ that i can drive there and pick up supplies to save shipping. i'm planning to get the mortar, insulation board and blanket, chimney, from them and source the bricks locally.
is the hearth insulation set on a skim coat of mortar, or sand, or caulked down in some way, or is it just pressed down from the weight of the bricks? seems like it could move over a month+ build if not anchored.
i see folks adding a bottle/can to the top of the vermiculite insulation, presumably as some kind of vent. what are the details on this? i don't really understand it.
i see some folks separated the chimney from the dome. i don't really see why this is necessary. shouldn't both heat up, and both have insulation? the dome will heat cycle far more than the chimney, so why so much concern?
if i stucco over the igloo, i'm assuming i still want the entire stucco igloo to "float" above the hearth for expansion. the FB instructions talk about rebar into the hearth and a mesh on that for stucco, but that doesn't seem right to me.
thanks for any help you can provide a newbie.
-SM-
-SM-
