Flame Fail button
  • Flame Fail button
    Hi,
    What does the red circle "Flame Fail" button on the control box do?
    G'day
    What control panel is this on?
    I'm not sure I understand your question
      The Modena2G oven. Im not sure what that red button is for.
        G'day
        Now that makes more sense. The Modena is a commercial oven and as such is probably fitted with gas or gas assist. Best to submit a question to Forno bravo direct.
        Far above the pay grade of us home oven builders
          Originally posted by ducati67 View Post
          Hi,
          Hi ducati67,
          This is from our technical support team:
          The Flame Fail button will illuminate when there is a problem with the burner. It is the fail safe signaling an error. The error can range from there being no gas, the probes (flame sensor or spark ignitor) not being in the correct position, bad thermal couple, or bad wiring. If the flame fail button is illuminated and they need some assistance in isolating the problem ask them to send in a ticket and i will give them a call.
          Let us know if you need any help!
          Mitch
          Forno Bravo
