Oven plans in millimeters?
  • Oven plans in millimeters?
    Does any one know where I could get oven plans that are in millimeters?
    The eplans for Pompeli are not metric. Just get the old calculator out. There are individual builders who have done some metric cad drawings but you have to search for them on the forum.
      Thanks Russell, had a look at your build and it's legendary....where's the like button
        1"=25.4 mm
          You can get them here:
          http://www.melbournefirebricks.com.a...d-pizza-ovens/
          Good luck
            1"=25.4 mm
            Thanks Dave, Eish
              Converting everything back and forth is driving me nuts!
              Cheers
              Greg
              My Build: https://community.fornobravo.com/for...erra-australia
              Photo Album: https://photos.google.com/album/AF1Q...JZX8QMLT_9mVj7
                It drove me nuts too! So, I made a one meter oven. I used a one meter stick and measured everything with it. made it simple for me.
                Lee B.
                DFW area, Texas, USA
                  Metric so much simpler than imperial, because it uses decimals rather than fractions. Also length, area and volume directly related. Eg 1000 cm3 = 1 litre. Try converting 1000 cu inches to cu ft or gallons, not easy.
                    According to Wikipedia, "The metre was originally defined in 1793 as one ten-millionth of the distance from the equator to the North Pole." I think it was the ideal size for a pizza oven
                    PS, I worked in aerospace and everything was in decimal inches - we never used fractions
                    My build thread
                      Originally posted by JRPizza View Post
                      ...PS, I worked in aerospace and everything was in decimal inches - we never used fractions
                      Wasn't that an issue with the Hubble Telescope...?
                      Lee B.
                        Might have been for Space X
