Hi,
So I’ve bitten the bullet, and am making a WFO. Initially I was sure that I was going to build a half barrel oven– then more and more reading on this site convinced me that the pompei was the way to go…
This weekend I’m planning on pouring the concrete base behind (and slightly on top of) a heavy limestone retaining wall.
Next step insulation board, then 38% alumina fire brick base, under a 42 inch Pompei dome. I’ll then use Isofrax blanket, and eventually render the dome. I’m hoping to be finished by Anzac day (April 25th).
Some questions though…
a)I live in a generally dry area, and the oven will be built on top of compacted sand that drains water well. Would you do anything special (I Was going to put plastic sheeting underneath the concrete base) to stop water getting into the concrete base. I will waterproof the dome, - but for other sections on top of the concrete base, not under the dome (eg the edges and corners) do I need to do anything special?
b)Are there any issue with using brick size 230X115X75mm (7.1x4.53x2.95)?
c)Would it be advisable to order many more bricks than what is calculated on the pompei oven spreadsheet? I have altered the spreadsheet to take into account my brick size. I live a long drive from where I am getting the bricks, and don’t want to make multiple trips…. It would be better to order more bricks, and some spares, but how many??? The pompei oven spreadsheet indicate that I will need to order 135 bricks, and that it will take 9 courses, plus one soldier course to complete the dome.
d)Any idea how much refractory mortar that I would use, and therefore need to order?
Thanks for all of your help, and the great site.
The Kid
The Kid
