I have a buddy who needs to do some pointing in his fireplace in his home. I was wondering if homebrew could be used or if he would be better of with a store bought fireplace mortar?
Tuck pointing fireplace with homebrew
The homebrew would be just fine if you have enough of the ingredients to spare. Gathering up the bulk homebrew ingredients for such a small job makes the store bought a better option. Though, most of the store bought is only rated for very thin joints. I'm fixin to do the same thing on an old fireplace and will be using the homebrew. I'm going to have to replace a few brick also. I'm guessing that regular mortar was used on this job. The joints swelled and popped large chunks of the faces of several brick.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
- Likes 1
I have all the ingredients sitting around (though I'm running low on portland) so I thought I'd just give him a dry mix that he can add water to when he gets it home.
Next question: I had been using homebrew in place of regular mortar on my external stuff that doesn't need homebrew because I like / am used to the workability of it. I may run out of Portland soon but have a couple leftover bags of stucco base coat.. Can that be used in place of mortar?
I would take the stucco back and get a couple of bags of masonry cement.
Edit: You will like regular mortars workabillity. There will be a color difference from what you have completed so far. But, you can get pretty close by adding some masonry coloring.Last edited by Gulf; 11-19-2019, 03:35 PM.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
- Likes 1
Also, If you so choose, the 1 part Portland/1 part lime can be replaced with 2 parts masonry cement for the remainder of your decorative brick.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
In the 3:1:1:1? So I could do 3:2:1 (sand : masonry cement : fire clay) to match what I've already been doing?Originally posted by Gulf View PostAlso, If you so choose, the 1 part Portland/1 part lime can be replaced with 2 parts masonry cement for the remainder of your decorative brick.
When buying masonry cement does Type S vs Type N matter for this application? I would definitely rather buy a bag of masonry cement than another 80 lb bag of portland this close to the end of my build.
Yes, to the 3-2-1. It will probably more closely match what you already have started on the decorative brick.
Type N would be best. The original recipe for type N is 50/50 Portland to lime. The lime in today's recipe has been mostly replaced with what the industry calls "or the equivalent". That is usually lime, crushed limestone, and some proprietary additives. There are very few, if any, small companies that will still bag the original formula.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
- Likes 1
Awesome, thanks!Originally posted by Gulf View PostYes, to the 3-2-1. It will probably more closely match what you already have started on the decorative brick.
Your welcome.
I just want to bring out for future builders that are in the planning stage and may be reading this thread that the Type-N masonry cement is not a substitute for the portland and lime in the homebrew. The "or the equivalent" for the hydrated lime in today's masonry cement is not refractory as is hydrated lime.
EDIT:
Are you sure that it was not a 94 lb bag?I would definitely rather buy a bag of masonry cement than another 80 lb bag of portland this close to the end of my build.
Last edited by Gulf; 11-20-2019, 05:52 PM.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
- Likes 1
You are correct, it was a 94 lb bag.Originally posted by Gulf View PostAre you sure that it was not a 94 lb bag?
That's great! I really did not mean to nitpick. But, over the years, there have been times when people have picked up the wrong product. The 80 lb portland (cement) just threw up a red flag for me. Bagged masonry products can get confusing to someone just starting out and may be reading this thread. I'm sure that you have a handle on this.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
- Likes 1
