Tall fire, yes. Wide fire too.
  • texassourdough
    • Nov 2006
    • 1719
    #46
    Re: Tall fire, yes. Wide fire too.
    Hi John!
    I think most of our ovens are a lot leakier for gases than we probably think. I am confident the bulk of the water evaporates (or transpires) to the oven interior during the oven spring period (which is when you want the bread skin to be soft and malleable so the bread can expand). The heating of the dough does three things to make the dough "spring". First it heats the gases in the bubbles in the crumb which cause the gas (mainly CO2 but some water vapor as well) to expand. Second, and supposedly more importantly, CO2 solubility in water and thereby dough decreases as temps rise so CO2 comes out of solution in the dough and forms more bubbles and/moves to the existing bubbles in the crumb. The third effect, which is much less significant, is the vaporization of alcohols which augments the CO2 effects and provides a lot of the aroma you recognize as baking bread. The largest changes in these factors occurs in the first 10 minutes or so and is mainly CO2 driven.
    I am a fan of McGee and I have read a lot of his book. While I would agree that most of the effect TYPICALLY occurs in the first 10 minutes (and maybe 6 to 8), the degree of oven spring is clearly a funciton of oven humidity as well. At 6 minutes the heat has not penetrated to the core of the dough so there is still potential for more oven spring if the skin of the loaf remains flexible (i.e. adequate humidity!). Experimentation with cloches suggests to me that oven spring can continue for at least 15 minutes and possibly 20 or more. (Tartine suggests a 20 minute "covered" approach with a dutch oven. I know I see some difference between 10 and 15 minutes closed and believe I see a diff between 15 and 20 - particularly in "tight" containers that don't lose much steam.
    Most ovens probably have about the right "steam loss" rate to make them work well.
    Bake On!
    Jay
    • lwood
      • Jul 2009
      • 632
      #47
      Any secrets on ramping up from a 2 lb to a 16 lb load?
      • texassourdough
        • Nov 2006
        • 1719
        #48
        Yeah, forget the mixer. It is easier to mix it in a big tub. Just do the whole thing by hand. Chad Robertson's book Tartine covers the process better than anyone else but it is kind of overkill to buy the book for just the process. The gist is to make your levain the night before, then mix the final flour the next morning. It is best to leave the salt out. Mix it until all the flour is wet, then let it sit about a half hour. Add the salt with a bit of reserved water (100 to 200 grams water for 15 pounds final dough) and squeeze the dough to get the salt mixed into the dough. You will feel it tighten significantly when the salt is added. Then give it a half hour and give it say 8-16 big stretch and folds (S&Fs), then every half hour for about two hours being increasingly gentle and decreasing the number as the dough develops and grows more fragile. After about 2 1/2 to 4 hours depending on temp, levain activity, etc. you should be ready to form loaves. Then you are back to normal process. I do spray the oven lightly with water but...not only lightly - just before I put in the first loaves and as I finish. Work fast loading. And don't open the oven until you think the bread is done though you may need to be early until you learn your oven.
        This approach should, with a little experience and practice, give you perfectly developed dough.
        Good Luck!
        Jay
        • Giulio
          • Apr 2011
          • 14
          #49
          that looks like GREAT bread!
          ive just built a 1.2m tuscan domein the tasmanian highlands.It seems to hold heat extremely well,but I havent attempted bread yet.Cant wait!
          • SCChris
            • Jun 2009
            • 1213
            #50
            The big load that I did 2 weeks ago was done by hand in a 20 qt stock pot. I did learn that I the feel that I have been getting from 1.8Kg batches translates to the big batches. Yes it's more work because of the additional bulk, but overall, it's about "mise en place" and mostly about how to move and proof the dough so that you can load the oven quickly. I haven't gotten around to getting a proofing board but will..
            Chris
            • texassourdough
              • Nov 2006
              • 1719
              #51
              You will find larger batches of dough actually behave better and give better flavor than small ones - say under 2 kg.
