Soot deposits not burning away.
  • Robthebubble
    • Aug 2010
    • 11
    Hi all,
    I've got my oven up and running and done the usual curing process, this was done a couple of months ago. I've got the temperature up to 450 degrees but can't get it any higher which means that the soot isn't burning off.
    Just in case you ask, the outside of the dome is still cool to the touch.
    Do you think my fire isn't big enough, should I use some Eco logs to get a higher temperature as I currently use pine to get the fire going then oak blocks to keep the heat.
    Any help would be appreciated!
    Rob
  • Les
    • Sep 2005
    • 2945
    Re: Soot deposits not burning away.
    How big is the fire? You should be able to get flames to shoot out the front and the vent. After you do that for a couple of hours I cannot believe you won't be above 450.
    • Robthebubble
      • Aug 2010
      • 11
      The fires are fairly big buy not enough to get the flames out of the front and vent. I may make a bigger fire then and see how it goes!
      • Les
        • Sep 2005
        • 2945
        Thats half the fun - bringing on the fires of hell...
        • Robthebubble
          • Aug 2010
          • 11
          In that case I'll get a bigger fire going! I might try some heat logs to see if they make any difference. I also need to get some more oak logs too as I've run out!
          • Les
            • Sep 2005
            • 2945
            I was kinda being facetious. I have never needed a fire that large to get to temp. I would get one huge blaze going to see what that does for you.
              • 9208
              Try to fill the whole dome with flame.
              • Faith In Virginia
                • Oct 2010
                • 713
                I think the other point here it time. If I used a bunch of small wood (sticks) I could have a big flame but it would burn out quickly. My oven is not average and it take a good 2.5 hours to clear. Correct me if I'm wrong but and average oven take 1.5 to 2 hours to get to temp. So hot fire that burns steady for at least 1.5 hours should get a cured oven up to temp.
                  And, as always, the more you burn, the better your oven gets as you drive off the last of that residual moisture.
                  • lwood
                    • Jul 2009
                    • 632
                    Maybe your oven is still wet. Tell us about your insulation, how you cured it, are your dome-to-door ht correct (63%). A couple of hours with a roaring fire should get any oven up to temp, even my 60"er.
