Re: Maybe a silly question .... but ... here I go
Gudday again
Every oven is a bit different and there owners usually know them best I suppose
There are heaps of different doors on the forum some of them pretty inpressive too. If you would like to experiment with a door here's a simple way.
Make a simple door from unpainted untreated wood. Planks nailed together whatever, as long as it covers the entrance. Before you use it make sure you rake out any coals and ash . Soak the door in water for a couple of hours so it doesn't burn and use a couple of bricks/rocks to hold it up tight to the entrance. It's simple and you should find out then how your oven works on the heat stored in the ovens mass.
Don't be to worried about the temp if something's not cooked it just needs a little longer it will probably be extra tender for that extra time
Enjoy your oven
Gudday again
Enjoy your oven
