My Pompeii Design
  • jeeppiper
    Re: My Pompeii Design
    Interesting design. I can envision all kinds of heating troubles with this design. First, you will have a "wind-tunnel" sucking air in and burning wood like crazy. Second, the heating that you will get will be very uneven. Heating the floor will be difficult. Nice thing about the Pompeii design is that the airflow is inherently restricted, so you get a nice, steady slow burn of the wood, giving the firebrick mass to absorb heat.
  • stonecutter
    Originally posted by snyderadam View Post
    My original thoughts of the benefits of a "white oven" were to:
    1.) Eliminate fire ash and reduce smoke in the cooking dome
    2.) Add a design challenge to the project
    3.) Potentially maximize the heat management of the oven
    1) If you are running the oven at 700+ with dry hardwood, you will have very little ash and no smoke in the dome.
    2) If you have not built a black oven before, even if you are experienced at masonry, then you will have plenty of challenges...especially if you are going for tight fitted work.
    3) An occasional use black oven is more efficient than an occasional use white oven....much,much more in fact.
  • Tscarborough
    That is not a white oven, it is an externally fired black oven. It is even less efficient than a white oven.
  • snyderadam
    Here is my preliminary design of a "white" pizza oven:
    (hopefully they post right, I never posted images like this before)
  • Tscarborough
    A true white oven is heated from the exterior, that is, the heat flows around the exterior surface of the oven to heat it. This complicates the design quite a bit. The flue gases have to be directed around the mass of the oven while maintaining sufficient draw to maintain the fire. In addition to warming the oven, you will be warming the fire area and all the mass of the masonry used to contain the flue gases. You will also lose the benefit having the oven mass insulated. There is a reason no one builds wood fired white ovens.
  • snyderadam
    I live in Northumberland County PA. I am in the process of getting a quote for a firebox I had in mind to see if the cost would be reasonable. I will try to post my sketches by the end of the week so readers have a better idea of one of my concepts. Jeeppiper, I was wondering if you purchased firebricks and if so where. Currently, I found two brands of firebricks I can purchase in PA. The most common-Whitacre Greer (low duty firebrick as per Forno Bravo's plans). I also found an Empire-S firebrick from an ANH Refractories distribution center in Trevose, PA (close to where you live). The Empire-S is classified as a high duty firebrick by ANH, but meets the specifications as a medium duty firebrick (as per Forno Bravo's plans). Do you have any comments on these firebricks?
  • jeeppiper
    No experience with white ovens, but my guess is that it might be more difficult to get the higher temperatures, since you will be taking heat losses going from the box to the oven chamber. Also will depend on oven size. With a raging fire in my "Black oven" I can get it up to 1200 degrees plus! Cook a pizza in about 10 seconds and burn it in 11! Most folks don't seem to be bothered by the ash management. Just get yourself a long-handled wire brush. I also use a piece of 1" pipe to blow the ash off the cooking area. What part of PA are you located?
  • snyderadam
    started a topic My Pompeii Design
    My Pompeii Design
    Hello,
    I am considering building a wood fired oven this summer. I primarily want to make pizza in it but would also like to be able to make pot roasts and artisan breads. This past month I reviewed Forno Bravo's pompeii oven plans and searched numerous forums about pizza ovens. I like the concept of the spherical dome to efficiently diffuse heat and maintain even heat. While brainstorming different ideas, my dad and I came up with an idea of having an external firebox. I soon learned that this design is called a "white oven", in contrast with the standard "black oven". From my research I have realized that there is not too much information on "white oven" designs. Also, not many people have designed and constructed this type of design. My original thoughts of the benefits of a "white oven" were to:
    I am in the process of making preliminary CAD sketches and assemblies to both propose design specifications and communicate my ideas. I will post these as soon as they are sufficient to be understood by other forum members. I am open to any suggestions/comments about my project and look forward to your input.
    Adam
