Disposable insulated oven door
    • 2848
    G'day
    Its possible to build a disposable insulated oven door that works with about 15 mins of effort from materials found around you.
    Pretty ugly hah. But it works. I found a friend using this and I was amazed that it worked too .
    A piece of ply cut to size to fit the revel ( in this case 6 mm) a block of wood screwed to the outside to keep it upright. You could delete this part and just use a couple of bricks to hold it against the revel.
    The real important bit is the use of the aluminium foil. 3 layers wrapped around the thing. This provides the all important ...
    " insulation air gapes". It will prevent that ply from bursting into flame. And you can put your hand on the front of it without that much heat.
    It's not super efficient but it works and will survive more than one use if you replace the foil. You will however get pretty sick of the look of the thing and go on to produce a better door I'm sure
  • fornax hominus
    • May 2009
    • 157
    Re: Disposable insulated oven door
    Coincidently just posted this photo ..could have used the temp. door that day
      • 2848
      G'day fh
      Ouch!!! That's gotta hurt.
      Must admit it took 2 years before I trusted my door before I put the hardwood face over the ply
      PS your a gutsy man posting that ... "Goodonya" or Australian for " Good on You!
      This forum would be the better for our failures as much as our successes
      • fornax hominus
        • May 2009
        • 157
        Dave , as we say in the Ottawa valley '' Gi'day'' back to you, [the valley has one of Canada's few distinctive accents, a 150 year old Irish/Polish mash up ..both heritages from a land that the TH sound forgot.]
        it was a bitter lesson for sure and I'm keeping an eye on my current door . Wood as you probably know becomes pyrolized afer many exposures to heat , allowing it to ignite at a lower temerature than unexposed wood . So 5+ years in I should probably make a pre-emtive move and replace the wood facing , before I awake one morning to see my door smoldering ..again ..
