if the brick dome is on a layer of fire bricks do i need a insalation layer below the fire bricks
isalation layer
Re: isalation layer
unfortunately, perlite/vermiculite is the cheaper option... but the cost definitely balances out in the long run if you weigh it against the cost of wood in an uninsulated oven.Comment
Re: isalation layer
maybe you should build an earthen oven, or is it called a cob oven ? do a forum search, i bet thats the cheapest way you can goComment
