It seems to have a commercial trailer hot and cold water is necessary both for washing food and for washing hands (a constant 80 degrees f) I am currently building a 4' external oven and wish to mount it onto a 4' x 6' trailer, I shall design the work surface so it slides of folds away, I can also use cool box's to take care of the refrigeration aspect but was thinking, if I were to wrap 10mm flexible copper tubing around the dome surely it would be great for heating water but any ideas how I could rig this up so it worked properly....Seems I would have use the evil electricity to run a pump,,,,something I was hoping to avoid, Any ideas???? Thank you
Mobile oven regulations
Tags: None
Re: Mobile oven regulations
If you coiled the copper pipe around the dome and connected it to a tank on top of the oven the water will flow to tank. Many solar hot water systems use this principle, no pump required.Kindled with zeal and fired with passion. -
Rather than robbing the heat from your dome, you could put the coil around the flue. If it's a pizza only operation, there will always be a live fire and a hot flue. Remember, no matter how you do it, it may at some point run dry: I'd steer clear of soft-soldered plumbing fittings.Comment
Also, I think you will need to be able to regulate the temp (too hot will not be accepted). Can that be done without electricity?My oven (for now):
http://www.fornobravo.com/forum/f43/...ven-14269.htmlComment
Brilliant idea, I'd have to be careful about the centre of gravity being so high though. Could be dodgy on a trailer.Comment
Google Images "Hand Water Pumps" they are used in RV's and boats.
Or transport the water low on the trailer, and fill a higher container as needed.
CarlEnjoy life! It's limited, you only get as much as you take.Comment
I'm all about making everything possible myself, and trust me many times I take that to the extreme, but I've always figured if I ever go mobile(which I've thought about) I would try and get away with one of these:
Amazon.com: Coleman Hot Water-On-Demand Portable Water Heater: Sports & Outdoors
For the couple hundred bucks I just think it is worth my time and trouble getting a oven based system up and running reliably, and running off small propane tanks and batteries it is highly portable.Comment
