Hello wood-fired folks,
We're having a capacity issue at the restaurant. At peak times we run nearly 100 pizzas (14") an hour through our oven. We start the gas-assisted oven around 10am, and start making pizzas at 4pm. We always keep 1-3 logs in the oven during service. When we get busy, our oven floor can't keep up. Pizzas will cook on top, but won't cook on the bottom as much as we'd like. We've found a way to work around it - we finish each pizza for ~10 seconds in the "hot spot" at the back of the oven - but it's a lot to keep up with, and it really slows us down.
Has anyone else experienced this issue, or have any advice?
Ideas currently on the table:
Equipment: Forno Bravo Modena 2G 120G
Oven floor size: 48"x48"
Oven floor material: 2 1/2" firebrick
Floor insulation: 4"+ ceramic
Temperature: 750-800 degrees F
Heat source: modulated burner + wood
Thank you for your help!
- Lay an additional layer of brick for heat retention
- Pull up the brick and supplement/replace the insulation
- Start the oven earlier in the day
- Start a wood fire in the middle of the oven early in the day, and push it back before service
