Re: 81 Inch First Build (and first post)
The pan is the reflector. There will be a plate of high temp glass in front. I will make up a ceramic socket on the end of a threaded rod to slide in through the 2" pipe sticking out the back of the pan. The rod will have disks or spring wires to center it and be surrounded by mineral wool insul. An appliance (oven) bulb fits in the 2" pipe with room to spare and I will fix it so it just clears the inside of the pan by putting a stop on the outside end of the rod. The wiring will be high temp also. The idea is to be able to change the bulb from the outside of the oven without interupting the heating or baking cycles.
Roger
Roger
