I understand the role a flue liner plays in a residential fireplace chimney, but is it really necessary in an outdoor setting? I was thinking of just building a double wall chimney and capping it on the top with a piece of slate. Any advice?
Is a flue liner necessary?
Re: Is a flue liner necessary?
Originally posted by dmun View PostThat will work fine, it's just that a couple of lengths of 8" flue tile are MUCH cheaper than what you could build with firebrick.
You do not need firebrick, but if you are going by code, you need flue liner. It is faster and cheaper to use flue than to build a double wall chimney, anyway. For my BBQ pit chimney, I just built single wythe brick, but the heat going up an oven flue is much higher, plus all the joints will make creosote buildup an issue.
Md's question had nothing to do with the type of brick - just a way to get it done. Dude, your approach to the vent will work. I would go with Davids suggestion of using a clay liner. They are inexpensive and readily available - worked for me.Check out my pictures here:
Originally posted by Les View PostMd's question had nothing to with brick..So now everyone has more knowledge.
The 8" round is outside diameter - giving me an inside diameter of around 6".
Is that going to work?
I'd note that the 8" square clay flue liners from Superior are also outside dimensions . . .
thanks -
Dan
Round is better, 8" round should be fine. The (very rough) rule of thumb is 10% of the opening is the size flue required. Bigger is generally better, espcially with square or rectangular flues. So if you have an 18"wX16"H opening (288 SqIn), then a flue in the neighborhood of 28-30 SqIn is good. A 6" flue gives you 28.27 SqIn, so it should work just fine.
Originally posted by Tscarborough View PostRound is better, 8" round should be fine. The (very rough) rule of thumb is 10% of the opening is the size flue required. Bigger is generally better, espcially with square or rectangular flues. So if you have an 18"wX16"H opening (288 SqIn), then a flue in the neighborhood of 28-30 SqIn is good. A 6" flue gives you 28.27 SqIn, so it should work just fine.
I figure I've got a 2.5" x 19" rectangle at the bottom of the arch, or 47.5 sq.in. and roughly 1/2 of a 9.5" radius circle, or 283.5 sq.in. / 2 = 141.75 sq.in. Total = 47.5 + 141.75 = 189.25 sq.in. opening in my entry arch. My 6" inside dia. clay flue is 28.27 sq.in which gives me a flue of approximately 15% of my oven opening. Sounds like that's more than sufficient . . .
Time to press on.
