Only when it's windy do I have trouble at start-up of the flue won't draw. Anybody have a wind-proof flue cap?
Flue has trouble drawing when it's windy.
Our Facebook Page:http://www.facebook.com/pages/Stoneh...60738907277443Tags: None
Re: Flue has trouble drawing when it's windy.
Hi Iwood,
I have a supposed wind proof flue cap which is a circular piece of aluminium surrounding the flue cap. I have no doubt that it does prevent some wind from going down the flue. From what I have observed in my oven on windy days is that the wind blows into the oven chamber and disrupts the air flow which allows some smoke to escape out the front. As you said, it happens on windy days mainly on start up. I think due to the fact that on start up there may not be enough heat to have a strong enough draw to fight the gusts of wind that may blow in. Once the fire is roaring though, there?s not much stopping it.
Cheers,
Mick
Never experienced that with my flue and flue chamber which is larger than normal
My first thought when reading your post was that your flue is too small, probabl6 6" I guess and the chamber thsat catches the smoke and funnels it into the flue is also too small and not performing as it should.
The only time I have ever had smoke coming out of the front arch was when I was using a leaf blower on full chat to get the fire going with greener wood. Normally if rces the smoke and hot gasses directly up the 12 foot flue.
NeillPrevention is better than cure, - do it right the first time!
Neill’s Pompeiii #1
Neill’s kitchen underway
I had the same problem yesterday, we had some horrible wind blowing from all directions and start up was a bit of a problem but once going it was ok.
I did notice that there was less of a problem when I had the blast door on and the damper slightly closed to block off part of the flue.
Wind can't blow into the oven because the oven is partially enclosed and protected. I have an 8" flue and the gases are water-falling down the flue. This occurs mainly at start-up but strong winds can cause the problem, during regular operation, to a lesser degree. Maybe I will just have to live with it.Our Facebook Page:http://www.facebook.com/pages/Stoneh...60738907277443
Originally posted by lwood View PostWind can't blow into the oven because the oven is partially enclosed and protected.
Have you got a pic of the top of the flue?Last edited by brickie in oz; 01-11-2012, 04:24 PM.
Yes, it can blow down the flue. All I have on top of the flue is a conical lid with about 2 3 inches btw the lid and the pipe. No picOur Facebook Page:http://www.facebook.com/pages/Stoneh...60738907277443
Originally posted by lwood View PostYes, it can blow down the flue. All I have on top of the flue is a conical lid with about 2 3 inches btw the lid and the pipe. No pic
Ha Ha Brickie...good eye. No that's not my oven flue, it's my fireplace flue and it is way too short, have to lengthen it cause it does the same thing. My oven flue is much taller (3m) and round, but has the same type of cap.Our Facebook Page:http://www.facebook.com/pages/Stoneh...60738907277443
Originally posted by lwood View Posthave to lengthen it cause it does the same thing.
Maybe its the lack of space between the flue and the cap that is restricting the flow?
The other thing would be down drafts coming over the top of roofs.Last edited by brickie in oz; 01-11-2012, 05:07 PM.
Thanks brickie, what about the cap? I'm thinking that some kind of perforated metal or screen in the space btw the flue and cap.Our Facebook Page:http://www.facebook.com/pages/Stoneh...60738907277443
Agreed, will take of the cap and see what happens.Our Facebook Page:http://www.facebook.com/pages/Stoneh...60738907277443
let me take a pic of the other flue.Our Facebook Page:http://www.facebook.com/pages/Stoneh...60738907277443
