Originally posted by Gulf
View Post
Flue has trouble drawing when it's windy.
Once, I did not fire up my 1732 AD built fireplace during a British summer, the crows nested up there!. My neighbour convinced me to be cruel to be kind as the chick may fall in the chimney shaft. Firing up the fireplace resulted in a horrendous shake as the fire lit up all the straws that were thrown down the chimney shaft. The fire up the chimney lit up the area and the noise that had resulted from the air suction caused by having two fires one at the top and another at the bottom made it sound like a burning chamber from hell!
Every fall that same child (if he did not slide off of the tin roof in the spring) was supposed to venture back up there and remove the shingle.
