We have finished our vent and are about to attach the flue. I have read that you should only use a small amount of morter to attach it. How much is sufficent? Just a small smear of morter up the side of the flue and down on the firebrick it's resting on an inch or two up? Also we are planning on making a brick chimney around the flue. I saw there should be a gap between the brick and the flue. How big a gap? Is there any reason we shouldn't use regular brick for the chimney? I've attached photos. Any help would be appriciated. Thanks
Re: Attaching Flue
Gudday
Normal bricks are more than enough and lighter as well . I would leave a space around the ceramic flue to take into account Expantion. You could even put some insulation between the flue and brick if you like
I really do admire your arch that is very good work . I think you should post it at the top of the forum page for all to admire!
Regards daveMeasure twice
Re: Attaching Flue
Dave,
Thanks so much for the reply and kind complement! Sorry not to have replied sooner. Here's a photo of what it looks like now. All we're waiting on is a delivery of the ceramic blanket. Once we get the dome insullated we'll stucco it over and start the curing process! I can't wait to get the oven fired up! Thanks again!2 Photos
Re: Attaching Flue
Nice looking oven! You can (and probably should) start curing before you put on the insulation and stucco.
Re: Attaching Flue
Originally posted by deejayoh View PostNice looking oven! You can (and probably should) start curing before you put on the insulation and stucco.
Re: Attaching Flue
Originally posted by Niro View Postcould anyone please explain why the curing take place before the insulation, and what will be the effect if i start curing after i put installation and plaster
also needs to be removed before a render coat is applied. It all depends on how you plan to build the oven. Some builders have neither wet vermicrete or wet render on their ovens. The way I build ovens is blanket over the dome, then a layer of vermicrete, to even out the bumps and leave you with a nice firm substate to render against, a week of drying in the sun (hope there is some) the drying fires, then a cement render coat.
Which ever way you do it just make sure you dry it out slowly.Last edited by david s; 12-15-2014, 04:45 AM.Kindled with zeal and fired with passion.
Re: Attaching Flue
Thanks David..
I currently finished applying the insulation (blanket) and the first layer of a cement coat (there will be a second layer coat).
i wonder if to start curing now or after the second render coat?
and what was your method to maintain 300F and so on in the curing process
please advice
Re: Attaching Flue
please advice
Regarding the method for maintaining an even, low temperature, I use a method that we are not allowed to discuss (see curing thread). You can use heat beads/barbecue fuel to achieve a slow even burn also. Try to avoid too much direct flame impingement on the dome.Last edited by david s; 12-15-2014, 02:13 PM.Kindled with zeal and fired with passion.
