Should the door close off the chimney, or should the chimney be open with the door in place?
A related question is this... many designs feature a doorway arch and a second arch behind it with a slightly narrower diameter... this gives you a nice surface to put your door up against. Does it serve any other function (other than aesthetics?
I'm considering having an arch 22cm long (using 22cm firebrick) and then casting the entrance to the dome slightly narrower to achieve the same effect... is there any problem with this?
