dmun's 36" geodesic oven part II
  • #61
    Re: dmun's 36" geodesic oven part II
    David,
    I feel like a happy in-law -- proud to be involved. This is just great. Congratulations on your first fire, and may there be many more fires and great food for years to come.
    Complimenti,
    • #62
      David, FANTASTIC!
      Glad to see that first fire. Its been an inspirational treat following your project all these months. The tower is incredible. I know its been said before, but, your attention to detail, planning, and execution have only been matched by a few (if anyone) on the forum. This is one of those times where it can be said - you COULD give up your day job.
      Great work
      RT
      • #63
        Nice Work David!!!!
        My Oven Thread:
        • #64
          Master Time Maker and wow Master Brick Layer. A very nice and inspring journey you have taken us on. I stated to james one day that Your build needs either its own folder on the forum or a seperate section with links to the series. This is outstanding.
          • #65
            Here's a fun note: using my plans, the wild folks at MHA built a geodesic oven out of raw clay, and tried firing it the same day. Hilarity ensued.
            The money quote: "Beer, pizza and blowing things up - heater mason nirvana."
            I think the failure of this oven is less an condemnation of the geodesic system than the result of building a fire in any green clay oven.
            • #66
              Excellent! you are famous! I agree that the main problem seemed to be using uncured clay...
              My Oven Thread:
              • #67
                Obviously they forgot throwing clay pieces from their youth. Curing clay takes time and boy oh boy did they rush it. from the monolithic slabs that they were using the dome shapes would need about a month to cure and then fire before being put into place. Also you need to be very careful about introducing air into the clay piece as you make it.
                More beer and more fun than you can shake a stick at.
                • #68
                  just 2 words....absolutely fantastic
                  • #69
                    I love how they have Dmun's plans and pictures printed out and laying next to the oven on the table.
                    Ken H. - Kentucky
                    42" Pompeii
                    • #70
                      Beautiful work! You make building an oven an art.
                      sigpic
                      Raffy's WFO Build Thread
                      WFO Build Pics (Picasa)
                      • #71
                        It's been a while since you finished. How is the oven holding up? Since you used a thiner 2.5" brick, how long does it stay hot, how long to heat up. It seems that everybody who builds an oven gets cracks, do you have crack report?
                        SCChris
                        • #72
                          Yes, I got some cracks along mortar lines, the only one with a gap is in the center of the front firebrick arch. Nothing too alarming, nothing I'd want to crawl in the oven to repoint.
                          I think my oven takes the same 1 3/4 to two hours to heat up as everyone else's does. I don't think a thin oven is worth the trouble, mostly because now i better understand the forces at play in an arch/dome:
                          Auroville Earth Institute is a research, design and developing agency for vaulted structures, construction of various Vaults, Arches, Domes (VAD).
                          • #73
                            I had the feeling that once the tooling was created, your method was ultimately easier than working brick by brick. Most builds look like the process after the first course is fitting, cutting, fitting, cutting, always a custom brick. I want to maintain the stagered joints all the way up if possible and it looks like this becomes more of a probllem the higher you get, hense the custom brick syndrome. Mabey its not as bad as I'm working it up to be. Anyway, I felt that by cutting the triangles and assembling these into the pentagon and hexigon shapes, you had control over the actual size of the building units, and minimized the work and assembly time. I also had to wonder if creating tooling for casting the pentagon and hexagon shapes might not make building 2 or more ovens more practical. I'm resigned to use the tried and true course by course method.
                            Thanks for the feedback and the great build.
                            Chris
                            PS Great article. It nice to have arch dynamics all spelled out.
                            Thanks for the link.
                            • #74
                              WOW!! I've been a geodesic enthusiast for years. Only recently have I become a brick oven enthusiast. You've irreversibly joined the two in my head. I have to try this on my trailer-based oven project!
                              (Or at least in my head, if it turns out to be too impractical!)
                              • #75
                                Um, the geodesic oven is really thin, and therefore brittle. I wouldn't even think about it for a mobile oven. I predict it would vibrate apart on the first ride. Any sort of mobile oven is best with a Modular Refractory Oven Do a forum search for "mobile ovens" for much discussion on this topic.
