To all those with circular peak chimneys. I have a Duratech Stainless steel double wall 10" diameter (Outside) Chimney. The roof is completely done now and chimney sealed over as I cannot figure out how to flash the peak hole.
I am able to figure out how to cut the angled storm collar. What I cannot figure out is how to cut the flashing base so that when it is bent to the roof pitch, is makes a matching 10" diameter circle which the storm collar can be welded to. Hence I am reaching out for help ideas. What have other done? Perhaps I am approaching this completely wrong so other ideas would be welcomed.
I have searched the site, and found a PDF, but does not show how to create the collar to flashing connection.
Frank
Frank
