Crack in arch mortar
  • Crack in arch mortar
    Mortared the inner arch 3 days ago. Today I noticed a hairline crack which appears to run between a brick and the mortar....along the whole visible mortar line.
    It was a hot day 24 deg 'C and the bricks were sucking moisture like mad.
    Havent removed arch support yet.
    I didnt soak the bricks - but I do now on the dome.
    Is this crack anything to worry about ?
    What should I do if its a problem ?
    Re: Crack in arch mortar
    Most likely not a problem. Can you post a pic?
      It is an arch. Arches are in compression, so a crack doesn't hurt anything.
        Agree with responses above. I have had a hairline in my inner arch for 4 years and it has not changed after uncounted fires.
        Chip
          Thanks for the swift replies..Guys.
          Here's a pic....as you can see its prob less than 0.5 mm at its widest.
          Hope I'm just worring about nothing !
            That looks like it will never be a problem. Nothing has slipped. Onwards and upwards!
            Cheers ......... Steve
              Thanks to all who replied.
                I have the same issue on my inner arch. Some time has passed, have you had any issue since? I am a lil more optimistic after reading the comments from those who know.
                https://picasaweb.google.com/1029081...00165373509921
