I'm leaning toward using the Duratech 8" stainless steel chimney. I have three questions.
1. It appears that the anchor plate for an 8" chimney is a 12" by 12" square plate. What size should I cut in the bricks on my vent to accomodate the anchor plate?
2. Does anyone have good pictures of how the plate attaches to the vent? For instance, does the anchor plate get attached to the top of the vent and the chimney then starts at the top of the vent or is it somehow attached inside the vent?
3. Can you cover the stainless steel chimney with stucco and, if so, what do you need between the stucco and the pipe itself?
Thanks, Jim
Thanks, Jim
