I've got my chimney in place with a clay flue tile chimney "smoke chamber" and now a 3' double stainless chimney mounted above that. My question is what to coat the clay flue tile liner with? Could I use a traditional stucco base coat or will high temps create a problem with cracking on stucco since it will not be insulated. Or should I make a wet stucco out of high temp mortar to act like a coating? I have left over blanket insulation and was also thinking about insulating the clay tile first. Ideas welcome!
Stucco for clay flue tile
