My new oven build.
  • My new oven build.
    My first post so hopefully I haven't broken the forum.
    Some pics of my oven build, what fun!
    The finished oven looks great! to me. However, the flue out the top of the dome may leak a lot of heat. And, I'm not sure what that plastic wrap around then mesh is for? Let us know how it cooks.
      Thanks for the comment.
      I just reposted almost the same thing as it looked as if my post didn't upload - duh - sorry guys.
      The plastic wrap was to slow the cement from drying out too fast.
        So i wrapped the mesh first with plastic so that the cement wouldn't stick to it then i wrapped the wet cement in plastic to stop it drying too fast.
        I removed the mesh from inside once it was dry.
          I understand the last part. But, mesh is designed to reinforce concrete/stucco? Or did you use fiber reinforcement?
            I used scoria (volcanic rock /pebbles) as the aggregate, it is solid. Have got the fire up to 500 celsius (about 900 farenheit) and no cracking inside only a few hairline cracks in the stucco on the outside.
