Interested in the photo, how the smoke channels for the Pompeian stove are arranged. Any help would be greatly appreciated, thanks!
Furnace smoke channel diagram
Hi Egor,
Welcome to the forum. Here is a search of the Web using the key words "Russian Stove". There have been a few discussions about Russian stoves on this forum. I'm not sure just how detailed any have been. To find the exact routing for that set up you would have to find the actual builder. I did a search for that picture on the web and did not come up with any hits. I suggest that you go back to the site or media that you found this picture and start from there.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build -
Valentin from Moscow Russia is the builder who did a combination oven similar but it was not a smoker but rather individual cooking units you can see his thread on the Forum. The brick work was outstanding.👍 1Comment
OK. I think that understand the question. The chimney/flu is angled back and over the dome. It has been given a term called "squirrel tail" because of it's similarities to how a squirrel's tail lays back over and hugs it's back. Here is a recent thread with a couple of examples. Both of these were done with masonry flus. However it can be done with stainless steel piping and angled connections. Hopefully, others will post some examplesJoe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
First thing is go the Forno Bravo store site and download the free eplans. It is a little dated but will answer a lot of you questions regarding design and construction of WFO ovens. Second, under the Newbie Section of the forum there is a sticky called Treasure Archives which shows some of the more documented builds.Comment
UtahBeehiver
Please tell me if you have a topic on the forum where everything is described about Utahbeehiver's WFO Build?
How many inches is the build? The first row of the dome in the photo, the bricks are separate from the floor, the height was calculated from the upper (or lower) point of the floor to the dome?
Egor2021 are you wanting to build an oven in a place where you are going to have a roof and want to have the chimney vent out towards the rear of the oven? With the placement of the chimney in front of the pompeii design you can either build a design like Gulf linked to in post #5 above, or use metal pipe with an angle to direct the smoke to the back of the oven similar to the pictures in the link below. Let us know if this helps answer your question.
I plan to build pizza oven using FB great DIY PDF plan/tutorial. I have one little thing to solve beforehand. The place the oven will sit in is now under construction - I am building "pergola"-like structure with transparent roof (glass or polycarbonate) so now I am before some decisions: 1. Oven chimney cannot goMy build thread
https://community.fornobravo.com/for...h-corner-buildComment
Here is a discussion thread : Pompeii Oven with two openings??? Not much on the actual build but some good information. The builder is no longer connected to the forum but check out the finished pics and the builders comments at the end of the thread.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
