Hi everyone,
I had some questions about my oven which I built 11 years ago. It is certainly not perfect as I made several mistakes, but it has stood the test of time, mostly because I baby it. During the summer it is covered with a canopy when not in use, and wrapped up tight in the winter.
I really had two questions. The first are the cracks in the mortar of the outer chimney. This was made of a 3:1:1:1 mix. To repair these cracks, can I just chip out the cracked mortar and force fresh mortar in the joints?
The second are the cracks on the outer dome, which have been there for many years. I want to improve the look of the dome. After the firebrick dome, there is a thick layer of vermicrete with an outer layer of surface cement. I mistakingly did not use any chicken wire and/or insulation blanket between the layers. I was considering wrapping the whole dome with a few layers of chicken wire so there is a gap in between, then do another outer layer of fresh surface cement.
Thanks for any help. I've included pictures.
Stew
Stew
