"Micafil" block fill vermiculite???
  • Majic31
    • Apr 2009
    • 23
    I went to my local building supply looking for vermiculite to use as loose insulation over the ceramic fiber blanket I had wrapped around my oven... and they sold me "Micafil" brand block fill vermiculite. It says its for filling concrete blocks or walls and is water resistant. OK- but is it appropriate for the insulating job I bought it for?
    I got it home and poked a hole in one of the bags... it's close to the consistency of oatmeal-like flakes... is that what it's supposed to be? I may have had the wrong impression, but I thought it was supposed to be more granular, larger pieces so there would be air pockets...
    Can anyone tell me whether this vermiculite is appropriate as oven insulation?
  • Tscarborough
    • Oct 2009
    • 3341
    Re: "Micafil" block fill vermiculite???
    It is fine. Perlite is more granular.
    • Majic31
      • Apr 2009
      • 23
      Reassurance is always good...thanks for the reply
      I can't work on it today (too darn cold and the wind's gusting to 60mph), so hopefully tomorrow..
      • Tscarborough
        • Oct 2009
        • 3341
        I often get asked the coverage of a 4 cuft bag of perlite/vermiculite in a CMU wall. The answer, of course, is 16 if the wind isn't blowing.
        • meco211
          • May 2010
          • 81
          Think that i bought the same stuff, but it is called Zonolite. not sure i can use it to mix with Portland cement and use for my Hearth slab. this stuff is almost powdery looks like pepper almost
          Toby
          Columbus, NE
          • Majic31
            • Apr 2009
            • 23
            Originally posted by meco211
            Think that i bought the same stuff, ...this stuff is almost powdery looks like pepper almost
            Meco211 - not sure what you have, but I don't think it's the same product as mine (although it sounds like it's originally intended for the same purpose)
            As I said in my post - this "Micafil" stuff is almost the consistency of raw rolled oats, not as fine as what you're describing...
            • Tscarborough
              • Oct 2009
              • 3341
              Zonolite is perlite and is fine to use, no matter what consistency.
              • kebwi
                • Aug 2009
                • 1090
                Vermiculite is a form of mica. They actually look quite similar.
                • meco211
                  • May 2010
                  • 81
                  thanks for the response
                  Toby
                  Columbus, NE
                  • Johnny the oven man
                    • Jun 2008
                    • 399
                    Vermiculite is EXFOLIATED Mica. That is, it goes through a furnace @ 1000c and the mica expands.
