Ive started the quest to gather the ingredients to make oven number two.
Im going for red/blue clinker bricks for the corners (quoins) and am going to infill with basalt cut to size to fit.
Ive bought a load of Bluestone (Basalt) blocks that I still have to pick up.
Ive got Squints for the oven door and arch, I priced these at one demo yard and they wanted $3 each,
I ended up getting them at a different yard for 30 cents each.
Same with the bricks, the expensive yard wanted $2 each, I got them elsewhere for 80 cents each.
Id like a Welsh slate roof but at $4 each second hand for the slates Ill think of an alternative.
The oven will be a barrel type with clay pavers as the internal oven.
The oven floor will be 300x300x40 fire bricks recycled from the old oven with a course of solid reds underneath.
Insulation
Under the floor will be vermiculite.
On top of the oven will be 2" of ceramic blanket and at least 4" of vermiculite.
Any thoughts/ideas/remarks welcome.
I ended up getting them at a different yard for 30 cents each.Same with the bricks, the expensive yard wanted $2 each, I got them elsewhere for 80 cents each.
Insulation
the bricksaw I bought off epay has arrived so I can make a start on cutting the stone..
