Re: High Medium & Low Fire Brick Data
Well its good to know that many are happy with low duty bricks. Why is it that Forno Bravo recommends medium duty??? Like they say, I would like to "Enjoy the process" and want to make sure I pick the very best brick for my oven....
All it takes is one "expert" to throw things into a tizzy. There is such a wealth of information just on this forum about what works and what doesn't, it amazes me that there are so many questions, misconceptions, and half truths floating around.
I've said it before, do your homework and your build will go fine. This forum proves there are 1001 ways to skin a cat, and in brickie's case, roast it in the WFO
RT
Everyones an expert on things they know nothing about.Originally posted by RTflorida View Post"they are not optimal for pizza ovens since temperatures may exceed their limitations and crack"
RT
I get told constantly by house owner "experts" on the correct way of laying bricks.
Low duty are fine for ovens, personal kilns, and general purpose use. It is an abrasion rating more than a temp rating anyway. High duty refractory is used for things like cement kilns where you have tons of highly abrasive material literally rolling around inside them for years at very high temps.
brickie, that may be true. The so called experts that I talked with told me that industries are concerned with the specifics - the chemical composition, continuous heat rating, thermal expansion rates, etc. The generalized terms low, medium, and high are just that - generalized, and can include a farely broad spectrum of compositions.
Since I'm not in the industry, I had to trust what they told me and the information contained on the data sheets.
I guess I should have just voiced my disagreement with the statement concerning low duty - "they are not optimal for pizza ovens since temperatures may exceed their limitations and crack"
Totally untrue in my opinion, the data from the manufacturer will support that. Since low duty (fireplace bricks in the US) are readily available and considerably cheaper, it makes perfect sense to use them in our case.
Maybe in a commercial setting a higher wear rating may be desirable to avoid periodic hearth brick replacement, then again, health departments frown upon all of the joints in a brick hearth and require larger tiles or a continuous slabe for the hearth.
RT
I thought it referred to the wear duty of the brick, light duty is a soft brick, medium duty is a medium duty brick, and high duty is a hard brick capable of taking some punishment.Originally posted by RTflorida View PostThe terms low, medium, and high are generally used by the uninformed lay persons RT
I do not believe there are any standards in the firebrick industry. The terms low, medium, and high are generally used by the uninformed lay persons (like us oven builders).
Anyone that is into refractories knows these are generalized terms and the alumina content can vary by 10% from one manufacturer to another. A product data sheet tells it all. Stick with an alumina content in the mid 20% to mid 30% range and you are golden. As for low duty (which I used and have been perfectly happy), I have never seen any with less than 21% and have never seen any rated at less than 1700 F - well within what is needed for a WFO. I went with the cheapest available low duty, rated at 2300 F and I believe have a 23 or 24% alumina content. Cost was 77 cents each at a brickyard. The refractory specialist wanted over $2.50 each for what we would call medium duty, I think they were 38 or 39% and rated for over 3000 F. Overkill and over priced if you ask me.
RT
Hundreds of ovens, including mine, have been built with low duty firebricks. Our ovens rarely exceed 1000 degrees f, which is well within the ratings for these bricks. Our Australian friends, who contend with high cost firebricks, regularly build ovens with "pressed reds", with only incidental silica content, with apparently good results.Low duty bricks are best for traditional fireplaces where temperatures do not get that high since it is a mostly open design. They are not optimum for pizza ovens since temperatures may exceed there limitations and crack which would be a total bummer after investing all the time and cost of building a home made oven from scratch! If you are purchasing new bricks, get the correct duty (see below). If you already have low duty bricks, proceed at your own risk weighing the advantages of saving money against the risk of bricks that do not last.
When you start dealing with medium and high duty bricks, you start dealing with refractory dealers, with specialty pricing, and a reluctance to deal with amateurs.
4 Basic Fire Brick Ratings (Super-Duty, High, Medium & Low Duty).
High & Low duty bricks are more readily available since there are more applications for them in the field.
High Duty Bricks are used in heavy industry where temperatures get very high since the furnaces are tightly closed and the process demands these extreme temperatures. As a side note, these bricks are more difficult to cut and may get too hot for cooking pizza. (They will certainly last a long time)
Super Duty which is for really high heat applications and not a consideration for pizza.
Medium Duty bricks with an approximate silica content of 50% and alumina content of 35% are what Forno Bravo recommend. I assume since food cooking ovens (Pompeii etc) are semi closed, and experience temperatures higher than fire places but lower than industrial furnaces, a medium duty brick is recommended.
Mt Savage FireBrick in Frostburg Maryland produces a Medium Duty Firebrick (see attached Data Sheet) with a 59.9% silica content & a 32.9% Alumina content.
This is slightly different than the percentages specified by Forno Bravo (9.9% difference in silica & 2.1% difference in alumina) I wonder if these differences have a better or worse impact on pizza quality or if anyone knows of a manufacturer with percentages closer to what Forno Bravo recommends.....
Mt savage also has a HIGH duty firebrick that has a 34.5% alumina & 58.9% silica content which seems to be close to the recommended sweet spot Forno Bravo recommends which they to refer as their MEDIUM Duty with a slightly higher Alumina content at 38%?????? There is also something referred to as a super-duty which is not even a consideration. Seems the porosity is higher.....Attached FilesLast edited by gsanto; 06-24-2013, 08:11 AM.Tags: None
